ABS kicks in every time i brake
Old Mar 22, 2013 | 08:16 AM
dssnosher's Avatar
dssnosher
Default ABS kicks in every time i brake
98' GS400 with 320K km on on it.
I thought it's my front rotors and pads which came to its end of life but after replacement i still get the same thing. ABS kicks in a fracture of a second just before the vehicle comes to a complete stop. Its very annoying, especially on the street with 5 stop signs. I spoke to mechanic and he said it must be the sensor but doesn't know which one.
Has anyone experienced same problem? Any ideas what needs attention?
Old Mar 22, 2013 | 08:47 AM
HOLGER21's Avatar
HOLGER21
yes I have that same issue everytime with my 98 gs4. I started a thread on this an everyone said that its common for our cars to do that so its almost normal??.... is yours actually like kicking your brake back or does it make that weird noise as if its about to turn on? honestly I just left it like that an it doesn't always occur everytime I hit the brakes but it does happen often
Posted from ClubLexus.com App for Android
Old Mar 22, 2013 | 09:21 AM
R1emperor's Avatar
R1emperor
I would check the brake fluid level and maybe bleed the brakes as a start.
Old Mar 22, 2013 | 09:31 AM
DosyBoy's Avatar
DosyBoy
https://www.clublexus.com/forums/gs-...ing-right.html
Old Mar 22, 2013 | 09:41 AM
nar8ta's Avatar
nar8ta
Easy fix. My mechanic stated it is the wheel speed sensor. There are magnets at the ends which pick up metal shavings which hinder the sensor from read. Clean of the shavings and your good. My car use to do this constantly. Now no more noise.
Check all 4 to be sure.
https://www.clublexus.com/forums/gs-...s-tripped.html
Old Mar 22, 2013 | 01:08 PM
KingNasGS4's Avatar
KingNasGS4
Happening to me right now.
I got it diagnosed . thought it was the hub. Changed it and it came back.
Upon further review it was the teeth in my hub that the speed sensor reads are worn. So it's miscounting.
Very annoying
Old Mar 22, 2013 | 01:20 PM
AnimalB's Avatar
AnimalB
You could have an internal leak with your brake master cylinder. Can you push your brake pedal all the way to the floor with the car in park and turned on?
Old Mar 22, 2013 | 02:02 PM
GS4_Fiend's Avatar
GS4_Fiend
abs light on? check code.
Old Mar 22, 2013 | 03:03 PM
nar8ta's Avatar
nar8ta
Very annoying
Kosi....Rich fixed mine. Give him a call. He explained it to me and showed me pictures of my sensors full of shaving. Easy fix. Its doesn't trigger a code or light.
rmartin723
Jul 9, 2014 11:58 AM
redfloyd
Oct 17, 2012 03:37 PM
phamxOC
Suspension and Brakes
17
Jul 20, 2011 12:17 PM
carlos
Feb 28, 2011 05:54 AM
jpezGS300
Apr 12, 2008 02:15 PM
