ABS. Buzz with slow speed stop no lights tripped
Old Mar 10, 2013 | 07:04 PM
mickeyb's Avatar
mickeyb
Default ABS. Buzz with slow speed stop no lights tripped
Recently I get a hum or buzz noise when making a slow speed stop. Slight pulse in petel but no lights triggered. Lexus mechanic checked it out and said to wait or lights to trigger which will then indicate codes. Has this happened to anyone else? Any suggested fixes? Thank you
Old Mar 10, 2013 | 08:48 PM
CHINCHIN's Avatar
CHINCHIN
Maybe a wheel speed sensor? They are fairly easy to check, do a search on here so that you can rule that out.
Old Mar 10, 2013 | 09:56 PM
Meyagi's Avatar
Meyagi
my car has been doing that since i got it over a year ago, still no lights on. i used a computer scanner to monitor all the abs wheel speed sensors and they are all reading the same speed at the same time, so i have no idea whats going on. this is a symptom of a bad wheel speed sensor but i dont know how to determine what ones bad...
Old Mar 11, 2013 | 06:32 AM
CHINCHIN's Avatar
CHINCHIN
Just do a search. I found the thread in less than 30 seconds.
Old Mar 11, 2013 | 06:56 AM
kamlung's Avatar
kamlung
i always thought that was just the sound of the brake booster?
Old Mar 11, 2013 | 10:22 AM
Riksgs808's Avatar
Riksgs808
I just started hearing a little buzz noise too when I brake, but I have no pedal pulsing. A friend of mine said to make sure the rim back sits flush when I torque the rim down. My buzzing went away. I dont know if it will work for you cuz of the pulsing pedal. It doesn't hurt to try. It doesn't cost anything and will only take 5 minutes to do. Good luck
Old Mar 11, 2013 | 09:12 PM
fatduece's Avatar
fatduece
I got the same problem. My Abs is buzzing on and off. Its weirds....I hope the brakes dont go out! Lol.
Old Mar 11, 2013 | 10:01 PM
blacksedan's Avatar
blacksedan
it's the brake booster.
I replaced my brake booster and I now hear it but haven't had a problem
Old Mar 19, 2013 | 05:18 PM
nar8ta's Avatar
nar8ta
Easy fix. My mechanic stated it is the wheel speed sensor. There are magnets at the ends which pick up metal shavings which hinder the sensor from read. Clean of the shavings and your good. My car use to do this constantly. Now no more noise.
Old Mar 19, 2013 | 08:57 PM
t0nyt00nz's Avatar
t0nyt00nz
Nothing to be alarmed about..but like they said clean out the wheel make sure theres no shavings and it sits flush...should be good
Jesterking
Jan 16, 2019 04:57 PM
Crobe
May 28, 2018 08:48 AM
fuzzflyr
Feb 25, 2015 07:59 PM
langsdale
Jun 3, 2010 09:55 AM
p092576
Suspension and Brakes
Apr 28, 2006 10:39 PM
