help with hid conversion kit
Old Apr 4, 2012 | 03:38 PM
gs300green's Avatar
gs300green
Default help with hid conversion kit
I am looking to buy a HID conversion kit 8000k for my 98 gs300. I want to get it right the first time around, so what sort of things shoold I consider why buying.
Old Apr 4, 2012 | 03:58 PM
abounly's Avatar
abounly
http://www.theretrofitsource.com/index.php?cPath=32
Old Apr 4, 2012 | 06:37 PM
Lextasy671's Avatar
Lextasy671
^^yup..retros
Old Apr 5, 2012 | 09:22 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
The 98 Lexus GS300 uses a 9006 bulb on the low beam meaning you will need a 9006 HID kit.
8000k will definitely give you a lot of blue color output and while it may look cool it's not going to be that bright. The higher you go in color temperature you sacrifice light output just to get more color. There is no functional benefit in going with higher color temperature. All cars that come with factory equipped HID's use bulbs in the 4300k range.
Old Apr 5, 2012 | 04:14 PM
PHML's Avatar
PHML
Master Thread Closer!!
I'd recommend 6000k temperature....most are plug and play...unlike the older kits which require running wires to the battery.
Old Apr 5, 2012 | 05:21 PM
1sWt2GS's Avatar
1sWt2GS
ahh, running wires to batteries, good old days with the civic haha.
i as well recommend 6k, if you wanna do it right the first time retrofit.
a lot of people on the forums use DDM Tuning for HID kits. if you take this route, at least aim the beams downwards to minimize blindness to those in front of you!
Old Apr 5, 2012 | 05:30 PM
martin2301's Avatar
martin2301
real easy to install. just lower the beam of the light.. running 8000k on mine
Old Apr 5, 2012 | 07:17 PM
PHML's Avatar
PHML
maybe some eyelids will help instead of lowering the beam pattern.
Old Apr 8, 2012 | 12:58 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
I would personally go with 4300k for the brightest possible output. If you choose not to use a relay harness then make sure to use a ballast that has a low starting draw and is not as susceptible to voltage drops if you plan on using auto lights. XenonDepot Xtreme ballasts have a wider operational range then the XenonDepot Volt ballasts meaning that you can safely power these ballasts directly from the OEM wiring and are ideal for vehicle with "auto" headlight features.
Steve
Old Apr 8, 2012 | 01:49 PM
MrSuave's Avatar
MrSuave
I have the $30 kit from DDM Tuning Installed in my 00-2GS
8k Lowbeams
3k Fogs
LeD's Parking Lights
It is not required but I highly recommend installing a relay which is I think $10-15 each as to ensure enough power is fed into the ballasts. Plus you can utilize the other OEM Harnesses for another lighting purpose as you are only required to plug in one side for the relay to work.
Old Apr 8, 2012 | 01:54 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
be careful with using a relay harness that only has one fuse/relay for both sides. If the relay or fuse fail so do both your headlights.
Are you sure you got 8k and 3k? Your headlights have "purple" to them and your fogs don't really look yellow?
Here is a picture of 8000k:
Here is a picture of 3000k:
Steve
Old Apr 8, 2012 | 04:22 PM
MrSuave's Avatar
MrSuave
Yeppp.. 100% sure 8k lows
And 3k fogs.
Old Apr 8, 2012 | 04:30 PM
MrSuave's Avatar
MrSuave
And 3k fogs.
Old Apr 9, 2012 | 12:54 PM
rogzballz's Avatar
rogzballz
How long have your HID Bulbs or Ballasts lasted?
Brand recommendations?
Old Apr 10, 2012 | 12:08 PM
XenonDepot's Avatar
XenonDepot
Former Sponsor
I'm biased =) All I can say is that we have been selling HID kits since 2001 and have been a trust vendor on this forum since 2004.
Steve
chrisgs
Lighting
Feb 13, 2006 11:52 AM
lexussc4
Lighting
Nov 24, 2005 10:18 AM
japtat918
Lighting
16
Feb 18, 2005 09:04 PM
Ghetto-Pimp
Lighting
Jan 12, 2003 01:54 AM
