Need help with gauge instrument cluster
Old 04-13-11, 11:29 AM
mrcrx28
mrcrx28's Avatar
Default Need help with gauge instrument cluster
So I went to start my car and turn to ON, all power dies. I checked my battery terminal to make sure they are secure. Refastened and hop back to driver seat. Power is restored and car turns over and starts. Now, my problem is the gauge cluster needles doesn't light up nor work. The bottom lights; CEL, VSC, High Beam, etc all operate. Only issue is the needles and illumination. I checked fuses and all is good, check for footwell fuse and underneath hood fuse. What else can this issue be? Has this happened to anyone else? Car runs and drives like normal. Headlights work along with taillights and reverse.
Old 04-13-11, 12:36 PM
LexiBlue
LexiBlue's Avatar
disconected the ground on the battery for about 5minutes and it should reset the cluster.
Old 04-13-11, 02:02 PM
mrcrx28
mrcrx28's Avatar
Woohoo worked Great!!! Thanks Lexi. So, now the the telescoping steering squeals when it retracts back in place. I heard it's temperature weather based, anyway I can lube or spray some WD-40 on it.
Old 04-13-11, 02:36 PM
sakataj
sakataj's Avatar
use white lithuim grease instead of WD-40
glad u got your problem fixed but this has been covered several times. your a old member i know you know where the search button is
BTW i have always liked your pic, makes me laugh
Old 04-13-11, 03:30 PM
LexiBlue
LexiBlue's Avatar
anytime easy fix
j stuff
02-22-11 09:54 AM
sedge11
09-15-10 11:42 PM
robsnyder
09-28-09 09:17 AM
JAPPILAC
03-23-09 06:33 AM
buh_buh
10-21-08 10:33 AM
Quick Reply: Need help with gauge instrument cluster
