Turn blinkers blinking erratically!?
Old Jun 12, 2010 | 10:54 PM
Mr Jokster's Avatar
Mr Jokster
Thumbs up Turn blinkers blinking erratically!?
Ok, so put LED's in my turn signals for the front AND the back. I put 4 load resistors (one for each bulb) so that they wouldnt blink all crazy. Well today (many months after) they are now blinking all crazy? What happened? My hazards still blink fine... I'm wondering and asking, could it be the blinker relay that has gone bad? If so, I'm assuming its a different relay than what the hazards use? Thanks for any help.
Old Jun 12, 2010 | 11:58 PM
skperformance's Avatar
skperformance
The load in the load resistors have heated up and now have less ohms resistance.
Either replace them , or better throw them away as they can cause fires easy enough and get an LED flasher relay to replace the stock one , with mine it made me loose the alarm parking light flash but i couldn't care less as I have an aftermarket alarm . if I was really worried about the flash I could wire it into the hazard light to get it back.
Old Jun 13, 2010 | 12:15 AM
excluesive's Avatar
excluesive
+1 to SK... don't use resistors.
Old Jun 13, 2010 | 12:32 AM
Mr Jokster's Avatar
Mr Jokster
seams logical, but heres my question that makes me skeptical... 2 things. Why do the hazards still blink fine? and most importantly, how can all 4 go out at the same time?
where can I get the LED relay? I'm gonna search for it right now, probably find it before I get a response but just in case, please advise.
thanks for the input.
Old Jun 13, 2010 | 12:37 AM
Mr Jokster's Avatar
Mr Jokster
Are these them?
Technical Characteristics
Nominal Voltage..................12V
Operating Voltage...............11V...15V
Switch Current.................... 0.02A - 20A
Max. Current .......................20A
Flashing Frequency .............90 times per min
Operating Temperature......-40°C to +80°C
Life Time..............................200 working hours
Old Jun 13, 2010 | 12:46 AM
skperformance
Those are not them , the relay is a larger rectangle shaped unit with multiple pins to plug in a harness , that is for older 2 or 3 leg plugs. it is made for specific Toyota's .
The hazards blink fine since they do not use a thermal ( heat) circuit to open and close (on and off) as that is a safety feature to tell you it is not working.
Old Jun 13, 2010 | 01:21 AM
sleeper408's Avatar
sleeper408
Low on blinker fluid?
Old Jun 13, 2010 | 10:12 AM
VNN326's Avatar
VNN326
its the bulb fluid or the blinker compressor might be going bad as well. have someone check those out.
E46CT
CT 200h Model (2011-2017)
Oct 31, 2019 07:29 AM
Itaboutpj
Sep 28, 2015 12:52 PM
dci4life
Jul 17, 2012 06:41 PM
LtunedG
Mar 4, 2010 10:15 AM
h2osmokey
RX - 1st Gen (1999-2003)
20
Sep 29, 2007 06:45 PM
