noise from the back
Old Jun 7, 2010 | 06:48 PM
LudeNsoL's Avatar
LudeNsoL
Default noise from the back
Hey. while im driving and i go over little bumps i hear a noise coming from the back... sounds like something loose is hitting something,. i thought it was my rear suspension, but i changed it out and put the new coils in. and it still does it.. its kind of annoying. sounds like maybe my mufflers are loose and shake everytime i hit a bump.. but i move it with my hand and it feels stable.. what else could it be? the sound, sounds like its coming from the middle of the car to the rear.
Old Jun 7, 2010 | 08:44 PM
unclej's Avatar
unclej
i got the same problem
Old Jun 7, 2010 | 08:54 PM
2G300's Avatar
2G300
Read something on another forum similar. Guy said the problem ended up being rear transmission mount.
Old Jun 8, 2010 | 05:09 AM
LudeNsoL's Avatar
LudeNsoL
wow.. how can i find out if its the transmission mount?
Old Jun 8, 2010 | 04:21 PM
dejavu157's Avatar
dejavu157
i had rattling sound in the rear too. Dumb me, found out my amp fell into the dip on the sides of the trunk and was bumping on it making it rattle.. lol
Old Jun 8, 2010 | 05:55 PM
carbongs's Avatar
carbongs
there are air vents in the trunk on both sides under the stock jack etc... they are notorious for rattling.
Old Jun 8, 2010 | 06:11 PM
2G300's Avatar
2G300
He said they had the car up on the lift and just looked at all the mounts, said it was pretty obvious. Noise he had heard was like a Klunk.
Old Jun 13, 2010 | 07:22 AM
LudeNsoL's Avatar
LudeNsoL
So I found out what the noise was.. It was my rear brakes. I had my rear brakes done like 2 months ago and I guess when they put the rear brakes back on, they didn't put the shield back on correctly. so everytime i was going over a bump the brake pads would move causing a loud rattling noise.
Old Jun 13, 2010 | 08:18 AM
YviE's Avatar
YviE
I'm glad that you found the problem.
Why did they remove the shields for doing a brake job? Is that normal?
Old Jun 13, 2010 | 10:58 AM
LudeNsoL's Avatar
LudeNsoL
yea im really happy i found the problem too.. and idk if its called the shield but its the plastic clip that holds the pads in place. so every time i was hitting a bump the pads where moving making noise.
Old Jun 13, 2010 | 11:04 AM
YviE's Avatar
YviE
Oh I see. I thought you were talking about the big metal 'heat' shield behind the brake rotor.
shrinkwrap
Nov 20, 2021 11:39 AM
ttsport15
Mar 13, 2018 05:56 PM
roygao
RC F (2015-present)
May 10, 2017 02:02 AM
funcrusher
Feb 13, 2011 09:36 AM
fryedout
IS F (2008-2014)
Sep 25, 2009 09:41 AM
