spacers?
Old Mar 2, 2010 | 11:39 AM
denut-L's Avatar
denut-L
Default spacers?
Hey guys, just wondering what size spacers you recommend getting if you had this setup. Fronts 19x8.5 +38 with 235/35 - Rears 19x10 +43 275/30
Would like it flush with cut fenders.
Thanks
Old Mar 2, 2010 | 12:26 PM
importhope's Avatar
importhope
I would think a 10mm in front should do it...
Old Mar 2, 2010 | 03:03 PM
mex lex's Avatar
mex lex
25mm in the rear
Old Mar 2, 2010 | 03:49 PM
PHML's Avatar
PHML
Master Thread Closer!!
I know you want to be flushed...but how much are you dropped now? Are you ok running negative camber?
Old Mar 2, 2010 | 05:12 PM
GS300ToM's Avatar
GS300ToM
What pete said...before we can give u an answer..
Old Mar 2, 2010 | 09:23 PM
denut-L's Avatar
denut-L
My tires are not tucked, just sitting right at the edge with the fender. Thinking about lowering more if everything works out right. I'm not looking to have it sticking out or anything at all, just so it's as close as possible to the fender.
I was thinking about getting 20mm front and rear. What do you guys think?
I'm not looking to run negative camber.
Thank you very much.
Old Mar 2, 2010 | 11:04 PM
TopRamen's Avatar
TopRamen
what kind of rims are you running?
I'm have some 19x9.5 and 19x10 that I need to buy spacers for also.
Old Mar 3, 2010 | 12:05 AM
lo_dit's Avatar
lo_dit
20mm wont fit on the front unless you are pulled and shaved and cambered. esp with a 235 tire. the rear would be fine if you are cambered, you might have to raise the car unless you want to rub.
Old Mar 3, 2010 | 11:16 AM
denut-L's Avatar
denut-L
LC dynas
Thanks for the info. My front fenders have been rolled and i could make u turns when i had my car slammed but i'm not sure how it's gonna be with the 20mm spacers. I'm gonna probably get the 20mm for the rears then.
So Last but not least with the specs on my wheels and with 20mm spacers i should be close to flushed as possible right?
And with the 20mm spacers i would need to cut the rear fenders and rolled the fronts correct? without rubbing issues.
Thanks guys!
LexusK
Apr 28, 2016 09:29 AM
YoNadz
Jan 31, 2012 09:36 PM
iridebmx
May 24, 2011 09:27 PM
olemanGS
Jul 27, 2009 08:56 AM
bighitbike
Wheels, Tires & Brakes Forum
Mar 14, 2007 06:17 PM
