Help with ignition light..
Old Mar 2, 2010 | 10:28 PM
melski415's Avatar
melski415
Default Help with ignition light..
what can should i look for? or how do i fix?
Old Mar 2, 2010 | 11:03 PM
sakataj's Avatar
sakataj
well u could try the search bar on here and SEARCH for your problem....or maybe tell us what the problem is? i assume its out?
Old Mar 3, 2010 | 01:24 AM
melski415's Avatar
melski415
it's just out. i tried the search, but couldn't find anything.
Old Mar 3, 2010 | 07:23 AM
shvc1991's Avatar
shvc1991
If you know how to remove the trim around the ignition then you're all set. It's a #74 wedge bulb.
If you don't know how to remove the trim, all you do is grab the trim directly over the ignition at the bottom and pull up. It should come right out without any excessive force. Be careful not to lose the ring that goes around the ignition. Then you will see a black clip that you have to undo and the bulb should be resting there. It may take some muscle to get the clip back on right, but chances are you're not going to break it, so don't be afraid to push a little harder.
Old Mar 3, 2010 | 10:05 AM
sakataj's Avatar
sakataj
post # 7 shows you how its done....i was working on changing my CABIN TEMP SENSOR but it shows you the majority of steps
https://www.clublexus.com/forums/gs-...mp-sensor.html
Old Mar 3, 2010 | 11:21 AM
PHML's Avatar
PHML
Master Thread Closer!!
My old thread...
https://www.clublexus.com/forums/lig...s-of-pics.html
Happy modding.
pete
Old Mar 3, 2010 | 11:42 AM
melski415's Avatar
melski415
thanx a bunch guys
Old Mar 3, 2010 | 11:54 AM
sakataj's Avatar
sakataj
Originally Posted by PHML
My old thread...
Happy modding.
pete
i was looking for that before i posted that pete..
ManXP
May 16, 2013 07:42 AM
aeroelasti
Dec 12, 2011 12:58 AM
lserlohn
RX - 1st Gen (1999-2003)
Nov 3, 2011 02:37 PM
mann777
GX - 1st Gen (2003-2009)
Apr 16, 2011 11:57 AM
Dietz
Mar 2, 2009 10:24 AM
