Tail lamp replacement
Old May 13, 2002 | 05:46 PM
(f)-LEX-ible's Avatar
(f)-LEX-ible
Unhappy Tail lamp replacement
I have a '99 GS300 and it has blown it's first tail lamp. I can't for the life of me figure out how to replace it. I must be making this harder than it actually is.
Can anyone help?
P.S. It is not one of the tail lamps in the trunk lid.
Thanks!
Old May 13, 2002 | 06:09 PM
2SAVVY's Avatar
2SAVVY
Ok maybe I can help..
To change any of the bulbs you need to unscrew the whole tailight assembly from the back end..
When you open the trunk you will see 2 plastic caps covering 10mm bolts but there are 2 more bolts on the inside of the trunk behind 2 plastic covers that just screw out.. Behind those plastic screws are 2 - 10mm bolts but you need a deep socket to get at them.. Pop those 2 bad boys off then you can take the whole tailight assembly off to get to the bulbs..
Hope I explained that right..
Ken
Old May 13, 2002 | 06:40 PM
(f)-LEX-ible
Yes you did. Thanks!!!
Old May 13, 2002 | 10:02 PM
biggie27's Avatar
biggie27
just take it to lexus they should replace it for free, at least they did when mine blew
Old May 14, 2002 | 04:55 AM
(f)-LEX-ible
Ken
Perfect! I now have all of my tail lamps working!
Thanks again!
Old May 14, 2002 | 01:22 PM
2SAVVY's Avatar
2SAVVY
Thanks again!
No problem.. Glad I could help!
Old May 14, 2002 | 03:01 PM
whitels's Avatar
whitels
Why did you bother to change it. That's covered under warranty (if you're under 50K).
Old May 14, 2002 | 06:09 PM
(f)-LEX-ible
It is just not worth a special trip to the dealer. I have 52K miles but an extended warranty till 100K.
L-Sports
Dec 10, 2018 08:57 AM
pudieinpa
Aug 14, 2005 04:43 PM
tiguy99
Jul 9, 2004 11:03 PM
hongkongrr
Sep 18, 2002 06:06 PM
wytemike21
IS - 1st Gen (2001-2005)
Jul 19, 2002 08:07 AM
