shifter problem
Old Jul 15, 2009 | 07:50 PM
flexspeed's Avatar
flexspeed
Default shifter problem > please help. cant put in gear
hi.... i'm new to the toyota as i'm a honda person...i just got me a 98 gs b/b,
there a couple thing wrong with the car and i would like to get some of your help..... i know its cost more money to modify the GS then my integra, but i know what i'm going to go through as i want a new project and soemthing diff.
too many honda out there...lolz....
n e ways..... the guy told me there no ac and the shifter will not shift unless you manual unlock then put it in drive or to put back in park... hope u know what i'm talking about.
i wasnt sure if its the neutal saftey switch or the solinoid of the shifting assembly. i try to goggle it and cant find anything...i called the dealer about it and they told me to best bring it in to connect to a machine and it will tell me whats the problem...rather then guessin or buying the wrong part... both part is about 300 dollars... now for teh ac... he say when he try to charge it.. it wont take it... so unsure of the compressor is bad or so. it blow hot air. i'm going to do some testing on it.....
any of you have any idea or opinion.. please let me know... i try to save some money b4 going to the dealers.....
my plans for this car is to do the 2jzgte swap, and convert it to manual...will post picture soon.... i'm in the process of working on my friend sc300 boosting.
also my car have 159,000 miles.... thanks to everyone..
Old Jul 15, 2009 | 07:51 PM
flexspeed's Avatar
flexspeed
also is anyone here from jacksonville, fl .... maybe i can meet you guys or gals for some tips and ideas... laterz
Old Jul 16, 2009 | 06:07 AM
flexspeed's Avatar
flexspeed
hhhmmm.... bump...no one can help? i try to research b4 i posted.... well... i give a little more time...laterz
Old Jul 16, 2009 | 09:14 AM
AsGs300's Avatar
AsGs300
HTML Code:
... Sigh.... the Gs's are the new Hondas now!
sorry couldnt help you much with your problems, sure someone here can
Old Jul 17, 2009 | 09:32 PM
flexspeed's Avatar
flexspeed
hey thanks asgs300, for responing....i tot this site will be lots of helps....i guess not many people have the problem i'm having now....i will figure it out, i thought it be easier to get help....
n e ways.. one more problem i have i dontkno if i mention it or not but when i reach at 60mph, my steering wheel shake, butonce it hit 70mph, its stop and drive smooth....any idea? i figure will can be unbalance, but it got to be something....i will use my friend wheels to see any diff. going to change ball joint, and tie rod when i'm lowering it...
hope soemone out there will give me the opinion about the shifter problem
Old Jul 17, 2009 | 10:13 PM
BLAZE's Avatar
BLAZE
Check the fuses under the drivers side for the shifter interlock. There is one that controls that. Even if it looks fine, swap it out. There probably won't be a specific fuse ( in the lexus owner's manual) but just try it out one by one. I had the same issue with my 98 gs400 and found out it was the fuse, Work's perfect now. A/c might be a bad evaporator, bad drier, compressor or expansion valve. Go to an a/c shop and let them diagnose it. Good luck and welcome.
Old Jul 18, 2009 | 12:42 PM
sakataj's Avatar
sakataj
Originally Posted by AsGs300
HTML Code:
correction the gs300's are the new honda's i like to think the gs430's are still like the REAL integra type-R's
Old Jul 18, 2009 | 01:26 PM
GS4_Fiend's Avatar
GS4_Fiend
^ He's drunk.. But he's right!
Old Jul 19, 2009 | 09:34 PM
flexspeed's Avatar
flexspeed
the shifter sometime work and dont.. but usually it dont work..... i will check the fuse... but there time i can put it in gear then it wont........will update infor soon.....thankz
Old Jul 20, 2009 | 01:26 PM
Oleg400's Avatar
Oleg400
What are the gs400's the new rsx type S
Old Jul 20, 2009 | 01:42 PM
macd7919's Avatar
macd7919
Check the brake switches on the brake pedal assembly.
Old Jul 24, 2009 | 01:28 PM
sakataj's Avatar
sakataj
i know....
ha not even close.... lol maybe the rsx but def not the TYPE-S
mojosc300
Nov 16, 2014 03:28 PM
snook
Nov 16, 2009 09:22 PM
acc
Apr 30, 2008 05:16 PM
kargahi
Apr 2, 2008 08:10 PM
