is it possible?
Old Apr 12, 2009 | 08:12 PM
excluesive's Avatar
excluesive
Default is it possible?
I have a gs430, I wanted to know if the is a way to lower the RPMs at cruising speed. Is there a way to make the 5th gear longer? Right now I can cruise at 75 at like 2500 rpms or so. Is it possible to get that down to lower that? I want to gain some MPG's on highway cruises. Will this affect my other gears and how they shift?
Old Apr 12, 2009 | 08:21 PM
swat1727's Avatar
swat1727
the gs3 cruise 75 at over 3k. i would like to know too
Old Apr 12, 2009 | 08:24 PM
excluesive's Avatar
excluesive
u can switch over to the gs430 set up, but you will lose acceleration.
Old Apr 12, 2009 | 09:47 PM
I8ABMR's Avatar
I8ABMR
My older G35 sedan was the same way, and it guzzled the gas. The 6 speed technology helps. Unless you plan on some solid mods to the transmission I would say there is not a lot you can do other than slow down to save gas
Old Apr 12, 2009 | 10:31 PM
excluesive's Avatar
excluesive
ok sounds good
Old Apr 12, 2009 | 10:33 PM
VipDout's Avatar
VipDout
19x11.5 -51
Hmmm would have to say you would have to switch out the rear end , dunno which one though
Old Apr 12, 2009 | 10:34 PM
GS FONZy's Avatar
GS FONZy
bigger wheels/tires.
Old Apr 12, 2009 | 11:12 PM
excluesive's Avatar
excluesive
if i switched out the rear end, wouldn't this affect all the gear ratios? i am really only looking for a longer 5th
YIKES!
JHarding
Aug 13, 2018 07:37 PM
SUNUK
Oct 13, 2017 12:37 PM
jgr7
Dec 30, 2011 07:50 PM
fordsvtmfl
Performance
18
Nov 4, 2008 09:09 AM
chino78
May 24, 2001 03:25 PM
