Engine Covers
Old Mar 11, 2002 | 08:31 PM
R.U. IN AW?'s Avatar
R.U. IN AW?
Default Engine Covers
Hey everyone. I was hoping someone can explain this to me. During my search for a GS3 model, I noticed that the 2000 GS3 had engine covers and 1999 did not. If they are supposed to have the same engines, why did the 2000 come with the cover? Just wondering, because if that is the case, can we take the engine cover from a 2000 and put it on the '99? Also the engine cover dress the engine a little bit more. Thanks for all your help.
Old Mar 12, 2002 | 10:48 PM
GSAristo's Avatar
GSAristo
I looked into the same thing back when the 2000 GS300's came out. In short, the 2000+ engine cover for the GS300 will not easily work on the 1999 GS300.
I actually bought the engine cover from my local dealer. The parts guy said it should fit no problem. So I went ahead and special ordered it, along with all necessary mounting hardware. When I got it home, I tried to put it on and found out that:
1) the engine cover has 4 mounting points
2) the cover over the spark plugs has the necessary holes for two of the mounting bolts, cool
3) the intake manifold does NOT have the necessary holes for the other two mounting bolts, not so good
The only option would then be to replace my intake manifold with one from a 2000+ GS300. At this point I didn't bother to ask how much because I had a feeling that it was going to be expensive (the cover itself was like $150, if I remember right).
Luckily for me two things came out of it:
1) I was able to get a refund because the parts guy admitted that he was wrong, and that it would be too costly to mod my car to get it to mount
2) my front RMM strut-tower brace would not have fit if the cover did fit due to the tight clearance
Old Mar 13, 2002 | 06:36 PM
R.U. IN AW?
Default Thanks AL,
Thanks for the info. Saves me the hassle of finding out the hard way.
TCM55
IS F (2008-2014)
Jun 3, 2021 12:28 AM
jaxxx
Jan 6, 2011 01:28 PM
projekt
Jul 13, 2007 09:45 AM
HKGS300
Feb 7, 2005 12:18 AM
CamRen
Jan 14, 2002 07:16 PM
