Engine Cover for 1992 SC4
Old Jul 11, 2007 | 05:42 PM
projekt's Avatar
projekt
Default Engine Cover for 1992 SC4
i bought a engine cover for my sc4...but for some reason it doesnt bolt ......is it me or an engine cover cant go on a 1992 engine
Old Jul 11, 2007 | 05:56 PM
RedPhoenix's Avatar
RedPhoenix
different model 1uz it came from. you can get it to go on with a little modification.
whats not letting it go on?
Old Jul 11, 2007 | 08:57 PM
projekt's Avatar
projekt
well he had a sc4 and i have a sc4 but he has a 96......and i have a 92.....well it goes on top but doesnt actually fit on top like there is to much of something underneath of it...plus the nail holes dont touch so i need a lonnnnngggg screw
Old Jul 12, 2007 | 05:09 AM
Blizzy's Avatar
Blizzy
you may have to unbolt the plastic pieces covering parts of your own engine first (not sure if you did that). also, the studs that hold the cover on are indeed very long.
Old Jul 12, 2007 | 10:45 PM
projekt's Avatar
projekt
where can i get the screws that are long enough for the engine cover????
Old Jul 13, 2007 | 06:34 AM
Blizzy's Avatar
Blizzy
you could order the exact part at the dealer. Or, if you knew the thread pattern, you could pick some up at the hardware store. I think there are three bolts, and they are probably only a couple bucks each at the dealer.
Old Jul 13, 2007 | 09:45 AM
Gunnar's Avatar
Gunnar
If they're as long as the top throttle body bolts on the SC3's, he's likely going to have to go to the dealer. I hit up 4-5 different hardware stores around KC not finding anything long enough before I ended up spending $2 at the dealership.
TCM55
IS F (2008-2014)
Jun 3, 2021 12:28 AM
jaxxx
Jan 6, 2011 01:28 PM
SC3coupe
Jul 10, 2010 02:46 AM
SC3coupe
Jul 7, 2010 04:38 PM
