Need help diagnosing a problem!!!!!!!!!!!
Old Feb 22, 2009 | 04:24 PM
criminalR1's Avatar
criminalR1
Exclamation Need help diagnosing a problem!!!!!!!!!!!
alright heres the deal...............I replaced the starter about a month ago...not sure if that had anything to do with it...but thats when it all began ....now every once awhile ill got to start the car and it cranks but wont fire..........like to day went shopping store to store parked ran in for like 5min came out and it would not start.......25 min later fired right up ........it runs great when it starts ...and does not throw and codes.....its happend 4 times in the past month and .......I'm stumped....i was thinking crank angle or cam sensor but it would throw a code it it was.....any help with this would be greatly appriciated............
Old Feb 22, 2009 | 08:22 PM
criminalR1's Avatar
criminalR1
Bump!!!!!!!!!!!
Old Feb 22, 2009 | 08:49 PM
mex lex's Avatar
mex lex
Have you ruled out the battery yet? Sometimes when you get them recharged and it shows the battery is fine, it isn't.
Old Feb 22, 2009 | 09:11 PM
UncleRay's Avatar
UncleRay
Does it make a sound when you try and crank it? I recently had mine changed, and in the cold, it'll make an "eeeee" sound when holding it to the ignition.
Check your battery like mex_lex asked. Definitely a possibility that your battery isn't holding power, or has little or no power at all.
Old Feb 22, 2009 | 09:23 PM
krazyGs3's Avatar
krazyGs3
crank and no start sounds like a crank sensor, but try switching you key. It happened to me. crank no start, ran in the house tried my valet key and it started. Something to try..
Old Feb 22, 2009 | 10:31 PM
tomtsops's Avatar
tomtsops
friend of mine has a similar problem (not on a GS), they replaced battery, put on new terminals.. nothing seemed to solve it. the problem was later found to be the distributor.. there was a crack in it, and when it was damp outside (usually in the mornings) it wouldn't start because water would get in...
Old Feb 22, 2009 | 10:43 PM
criminalR1's Avatar
criminalR1
yeah...new battery..starter..plugs.....a friend told me to try my other key and see if it does it..............no strange sounds.....cranks like normal .....just don't fire for some reason.....I would think if it was a sensor it I would think it throw a code......so Im starting to lean to the ignition.......is it possible my key is basically dying????.....and its not disengauging(my spelling suck) the anti-theft..system.......
Old Feb 22, 2009 | 11:30 PM
sam430's Avatar
sam430
The key wouldn't be dying... it's more likely that the ignition switch is worn out. Then again, you said it cranks.
Old Feb 22, 2009 | 11:31 PM
GS4_Fiend's Avatar
GS4_Fiend
Check for spark and fuel if it is cranking normally. If there is "no spark AND fuel at the same time". Then it is the CKP sensor. GL!
Old Feb 22, 2009 | 11:35 PM
jcat_350's Avatar
jcat_350
check your fuel filter too, as well as fuel pump.
Old Feb 23, 2009 | 12:04 AM
sam430's Avatar
sam430
It's very easy to get to the fuel pump... just grab the seats and lift. I think when you turn the ignition on, you'll hear a hissing sound (not sure if that means it works or not).
Old Feb 23, 2009 | 09:28 AM
criminalR1's Avatar
criminalR1
thanks for all the help .........keep it coming if you got more ideas on this mistery problem..............I'm gonna start replacing things 2 day
Old Feb 23, 2009 | 11:18 PM
criminalR1's Avatar
criminalR1
My brain is'nt functioning at the moment........CKP sensor?????????
Old Feb 23, 2009 | 11:24 PM
GS4_Fiend's Avatar
GS4_Fiend
crankshaft position sensor
KassuX97
May 26, 2019 09:25 PM
LS400BOY
Feb 17, 2016 11:27 PM
Mandel73
Jun 29, 2012 07:25 AM
lalexusgs
Jan 24, 2006 01:29 PM
kino1161OLD
Maintenance
Dec 12, 2003 03:20 AM
