Annoying CEL code : P-0171
Old Dec 30, 2008 | 11:09 PM
VNN326's Avatar
VNN326
Default Annoying CEL code : P-0171
well, i was just driving and a cel just went up from no where. i got the code read and it said it was P-0171 (system too lean). what should i change to fix this problem? thanks.
Old Dec 30, 2008 | 11:16 PM
AYEmike's Avatar
AYEmike
The MAF sensor is dirty, take out and spray the MAF sensor with something like brake cleaner. make sure its dry before installing it back in. check for a dirty fuel filter also.
Old Dec 31, 2008 | 12:20 AM
Debonair's Avatar
Debonair
Do not get Brake Cleaner ANYWHERE near your MAF sensor. You can find a spray cleaner specifically made for MAF sensors at your auto parts store if you need to clean yours.
Fuzionn, are you aware that this car does not have a standard fuel filter? Its part of the pump.
Old Dec 31, 2008 | 12:21 AM
kit cat's Avatar
kit cat
and make sure you don't touch the element itself, it is VERY sensitive.
Old Dec 31, 2008 | 12:37 AM
GS FONZy's Avatar
GS FONZy
FYI - our cars are not known to have a fuel filter like other vehicles. There's a filter in the fuel pump, but does not need to be changed like on other cars that have a remote fuel filter.
Old Dec 31, 2008 | 10:07 AM
VNN326's Avatar
VNN326
so its most likely my MassFlow Air Sensor? not a fuel problem, thanks for the help guys.
Old Dec 31, 2008 | 03:14 PM
dusouth's Avatar
dusouth
same thing happen to me weeks ago (po171) maf sensor.
i used commpressed air to clean it out
Old Jan 1, 2009 | 08:14 AM
Rock-a-Lex's Avatar
Rock-a-Lex
I was getting that for a while myself and my MAF was clean as a whistle and then I cleaned it again. Same code...how much for a new OEM MAF sensor? Can you get this on Ebay?
Old Jan 1, 2009 | 10:02 AM
lexusscturbo's Avatar
lexusscturbo
Sewell Lexus or PM Aligia
Old Jan 3, 2009 | 02:00 AM
GS4_Fiend's Avatar
GS4_Fiend
Clean your MAF. If doesn't work, maybe it's time for a new one. =)
SC93
Jul 30, 2013 08:06 AM
BiggerOkie
RX - 1st Gen (1999-2003)
Mar 27, 2012 01:00 AM
richonline
Nov 11, 2010 05:11 PM
jimbo22s
Maintenance
Dec 24, 2008 02:58 PM
subal
Feb 19, 2004 01:56 PM
