Checking 0-60 time?
Old Nov 11, 2008 | 09:24 PM
pitmanr200's Avatar
pitmanr200
Default Checking 0-60 time?
I wanted to see how good my baby was running today. I have a 98 gs 400 with 168,000 miles on it. all stock. here is how i checked it. i put in power turned vsc off and right when i floored it with it in D i started stop watch and when I got to 60 on speedo i stoped it. I got 6.64. That seems slow. Is this right or not a good way to check it and if right how can I improve that. I thought about manual shifting or torgue braking it, but i think if I tourque brake it with it being 40 degrees out side im going to hurt it more by spinning. It just squeeled and took off the way i did it.
Old Nov 11, 2008 | 10:53 PM
litesoarer's Avatar
litesoarer
try turning power off.
6.64 sounds about right unless you've recently changed spark plugs, fluids and all.
Old Nov 11, 2008 | 11:08 PM
Spyder78's Avatar
Spyder78
CL Folding 25,000
If a stock gs is rated at 5.7 to 5.9 how in the world is 6.64 right?
Old Nov 11, 2008 | 11:24 PM
Deception's Avatar
Deception
that sounds like a 300
Old Nov 12, 2008 | 12:14 AM
Solo_D33A's Avatar
Solo_D33A
well, most likely magazine brake torqued, but since it's too cold, well, nothing you can really do... go blame global warming....
Old Nov 12, 2008 | 12:44 AM
litesoarer's Avatar
litesoarer
300 is closer to 8sec.
Old Nov 12, 2008 | 12:46 AM
litesoarer's Avatar
litesoarer
I meant that it sounds about right UNLESS you've done all that.
And have a fresh set of tires. Remember, no traction, no speed.
Old Nov 12, 2008 | 12:53 AM
pitmanr200's Avatar
pitmanr200
i have changed all fluids, but still need to do plugs. i may try torgue braking it and starting in low 1. seems so much stronger when you start in low 1 and shift manually. tires only have 5000 miles on them.
Old Nov 12, 2008 | 01:47 AM
litesoarer's Avatar
litesoarer
Do your plugs, then try it.
Old Nov 12, 2008 | 01:50 AM
Spyder78's Avatar
Spyder78
CL Folding 25,000
IMHO there is absolutely no way that you can drive, look at the road, the speedometer and a stop a watch at the same time. Get some one else to time you so that you can make some accurate measurements.
Old Nov 12, 2008 | 06:29 AM
litesoarer's Avatar
litesoarer
Oh, there's a way....Didn't they make an app for the iPhone that measures 0-60 times and such
Old Nov 12, 2008 | 08:48 AM
sakataj's Avatar
sakataj
yes but like most apps for my and others iphones its GAY and all the reviews on it (well alot) say its inaccurate. plus its not worth the 12.99 bucks they want for it. its called dynolicious for those like me with a iPhone who wanna look at it!
Old Nov 12, 2008 | 08:57 AM
Rippaflow's Avatar
Rippaflow
Sure there is LOL. Press the button when you press the gas...and when you hear that 1UZ shift into 2nd, pay attention and get ready lol.
Old Nov 12, 2008 | 04:05 PM
pitmanr200's Avatar
pitmanr200
i didnt have a problem. wide open 3 lane road and night with no one on it. car goes straight. i beleive its propably inacurate just being the clock shouldnt start untill the car actually moves not when i push gas. so that could be why its so high?
Old Nov 12, 2008 | 04:19 PM
BLAZE's Avatar
BLAZE
just go to the local track....
