New B here Need little help Please
Old Nov 1, 2008 | 08:21 PM
BilluAwan's Avatar
BilluAwan
Default New B here Need little help Please
Hi everyone I just joined these forums...just sold my 99TL http://tl.acurazine.com/forums/showt...732&highlight= and picked up 98 Gs300 ...I am car crazy and will start modification ASAP. I might need some help from you guys not fimiliar with Lexus parts whole lot! i have silve Gs 300 excellent condidion bought a car from its first owner and will post pics soon....I already have complete Kenwood Navi and Tvs an banging sound system set up which i will be installing it in a week and will post pics..for now i need little help here please!
1: When car is running lights are on, if i press on brakes or any interior lights, headlight blink a little as well inside lights blink just a little? is that battery is going or alternator is not giving enough power and is going? any Suggestions please? i have to fix that before i install the sound system
2 When I lock the doors from remote Everything Locks but driverside lock. I have manually lock and unlock the door?
3 Where Can i get notvery expensivecomplete Lip kit for the car?
4 There is a little plate which goes inside the gear shifter that is not there..when i change from park to drive i can see a big hole and theres no plate in side like every shifter should have...previous owner i think i might have forgot to put it back after cleaning...so iwhere can i get that...
Old Nov 1, 2008 | 08:28 PM
4play4dr's Avatar
4play4dr
1. most likely ur battery
2.most likely ur door actuator
3."not very expensive" is out of the question..all REAL kits are expensive..alot of replicas around if you wanna go that route
4.i dont kno what ur talking about
Old Nov 2, 2008 | 12:18 PM
mtparker18's Avatar
mtparker18
in #4, it seems he's talking about where the screwdriver goes to move the shifter.
Old Nov 2, 2008 | 10:03 PM
BilluAwan's Avatar
BilluAwan
yes its a plate inside the shift box which moves while you change from Park to drive..its missing...so i can see inside the shift box
Old Nov 3, 2008 | 07:09 AM
LEXUS_KID's Avatar
LEXUS_KID
WELCOME BilluAwan
Old Nov 3, 2008 | 07:37 AM
JoelGs's Avatar
JoelGs
#1. usually that is the alternator, if the alternator weak it will make the exterior or interior light dim on & off. When was the last time you had an alternator replace.?
#2. most likely it is DOOR ACTUATOR..
#3. the only way to get inexpensive lip is to MAKE IT YOURSELF...
#4. Manual shift slot...Check dealer to be exact....
Old Nov 3, 2008 | 01:11 PM
BilluAwan's Avatar
BilluAwan
i justgot this carcouple days ago..it drive like a dream extreamly clean from aperson I know....i amsure alternator was not changed.....i willget that checked out frommymechanic....what exactly and whreisthe door actuator? can i replace it my self
Old Nov 3, 2008 | 01:38 PM
MPLexus301's Avatar
MPLexus301
Old Nov 3, 2008 | 02:02 PM
JoelGs's Avatar
JoelGs
Door Actuator is locate on middle of the door on side where the door and pillar post meet..Let me see if I can post with some pix to help you out...Name:  Actuator.JPG
it should look like this!!! but you have to open your door panel in order to
see it...
Old Nov 3, 2008 | 02:33 PM
sleeperGS's Avatar
sleeperGS
WHOA, i totaled my 99TL and bought a 98gs...lol....
Old Nov 3, 2008 | 05:22 PM
BilluAwan's Avatar
BilluAwan
i had a 99 TL too check it out on acurazine.com under billu99tl
ruthkar
CT 200h Model (2011-2017)
Apr 1, 2019 12:18 PM
98_pullnem
Jan 24, 2009 02:58 AM
LexSaZ
Canada
Dec 12, 2007 02:48 PM
minh
Aug 16, 2003 06:25 AM
