EVAP help plz!
Old Sep 24, 2007 | 03:17 PM
Oleg400's Avatar
Oleg400
Default EVAP help plz!
I just got an OBDII reading and 2 codes showed up P0441, P0446.
Both are referering to EVAP failure/malfunction anyone know if this is a big problem? and how much it could cost to replace.
If anyone needs more info I can type exactly what it says on the code reciept's
Old Sep 24, 2007 | 06:14 PM
jz4203's Avatar
jz4203
I've got the P0446 code but not the P0441. Mine's probably the charcoal cannister (a $220 part, plus the labor is extensive and I've heard as much as $500). But I'm still in troubleshoot mode.
Anyway, if you do a search on P0441 or P0446, you'll see a lot of the information you're looking for. A hint is P(zero, not the letter)446.
Good luck.
Old Sep 24, 2007 | 06:53 PM
Stage3's Avatar
Stage3
Check your gas cap. Might be loose. If not, check the vacuum lines. one of them might be broken or just off it's seat.
JawnsGS4
Nov 11, 2015 03:22 AM
z3ds
Sep 15, 2014 05:18 AM
Maxx941
Jun 3, 2011 06:38 PM
JohnGS4
Apr 11, 2007 07:50 PM
emacblane
May 23, 2006 07:23 AM
