weapon r intake help
Old Oct 23, 2001 | 09:06 PM
lexon20's's Avatar
lexon20's
Default weapon r intake help
HI A FEW QUESTIONS
1. ANYONE KNOW THE HP GAINS ON THE DRAGON INTAKE AND THE RAM AIR KIT?
2. ON ANY INTAKE I DECIDE ON IF I RESET THE ECU BY DISCONECTING THE BATTERY WONT THAT RESET THE AIR/FUEL? OR DO I NEED THE ECU LIKE THE SRT?
3. WHAT DOES ERYONE RECOMMEND ?
TO ME THE WEAPON R WITH RAM AIR SEEMS LIKE IT WOULD PUT OUT THE MOST HP.
Old Oct 24, 2001 | 03:53 AM
LexusRules's Avatar
LexusRules
yea its great it makes power, when you install it you need to have the negative off of the battery which would reset the ECU anyways
Old Oct 24, 2001 | 06:19 AM
lexon20's's Avatar
lexon20's
thanx sasha
But if all you have to do is reset it y do they sell the swift racing? is it a waste of money? do you know the hp gains with that ram air from weapon r?and last i hear that the weapon r dosent come with brackets to hold it in place or a heat sheild. sorry for all the questions but i just wanna make sure i pick the rigfht setup.
Old Oct 24, 2001 | 12:43 PM
LexusRules's Avatar
LexusRules
when you reset you DO get more fuel, but still not quite enough SRT, Apex'i, And The Weapon*R ECU all offer more aggressive fuel curves
Old Oct 24, 2001 | 03:14 PM
RacingAristo
Guest
Posts: n/a
Weapon R does not have heat shield if you buy their intake. However, if you buy cold air ram (a pipe where cold air comes in from the outside of the car) together, heat shield is not that important. Or you can ask them and see if they are willing to sell you the air box.
The best place to buy SRT product is thru Mo @ SRT. www.suprastore.com also sells SRT HFI/ECU but it's more expansive.
Weapon R has the dyno on their web for IS300. You can use that as a reference.
Old Oct 24, 2001 | 04:36 PM
GlobeCLK's Avatar
GlobeCLK
Hey people.
Where can I get a Weapon-R intake with the pipe only, no filter? I have a Blitz filter with RMM intake, but the RMM pipe/adaptor sucks. So I want just the Weapon R pipe. Can I just get that and how much is it?
Old Oct 24, 2001 | 05:15 PM
enginyr's Avatar
enginyr
Banned
Will someone take a stand as too which intake is better...SRT or Weapon R/Apexi...?Prices?
Old Oct 24, 2001 | 05:29 PM
LexusRules's Avatar
LexusRules
Weapon*R / S-AFC is better, i took a stand there im too lazy to explain why sorry maybe tommorow
Old Oct 24, 2001 | 05:44 PM
enginyr's Avatar
enginyr
Banned
I shall count the minutes to hear your full reply
Old Oct 24, 2001 | 07:37 PM
RacingAristo
Guest
Posts: n/a
APEXi S-AFC can only change fuel ratio if I remember correctly while Weapon R claims that their ECU can alter air/fuel ratio and the ignition timing for each RPM. Sound very good to me except the price.
Old Oct 24, 2001 | 09:13 PM
lexon20's's Avatar
lexon20's
well do you think i would gain alot with the intake and ram air only, NO ECU? i think thats what i might do. does it come with the brackets to hold it up?
Old Oct 24, 2001 | 10:06 PM
RacingAristo
Guest
Posts: n/a
An intake will only give you couple horsepower (less than 10) and the cold air ram will also give you a little additional power (less than 10). Those will help to cut maybe 0.1 second but no more 0.2 second for GS as it's already a fast car. Without reprogramming the ECU, GS won't run at its optimal and that's why SRT, Weapon R, Biltz, APEXi and other tuners offer ECU.
I don't remember Weapon R having a bracket to hold up. (I may be wrong at this) I will let Sasha and Wei to answer that question.
Old Oct 25, 2001 | 11:25 AM
LexusRules's Avatar
LexusRules
yea weapon*r has a braket you can use to hold the intake up, its metal you have to bend
the intake itself is DEFINATLY A NOTICABLE IMPOROVEMENT esspecailly when you reset the ECU with the car, but with the S-AFC or Weapon*R fuel computer you will be able to gain more from it than with stock.
the best thign to do would be buy an intake, exhaust and pullies and then get S-AFC or Weapon*R, that is what will give you THE MOST power because thats when you are really freeing the air and making more power so tuning would be usefull
huss11
May 29, 2018 04:27 PM
AROD
Performance
Apr 29, 2003 12:43 AM
farajfad
Performance
26
Nov 3, 2001 11:07 AM
lexon20's
Oct 3, 2001 01:00 PM
babyboy
Sep 29, 2001 06:27 PM
