Removing lower engine cover
Old Oct 23, 2005 | 07:27 AM
sockfocks's Avatar
sockfocks
Default Removing lower engine cover
Will removing the lower engine cover affect anything?....If anyone else has please respond with any changes you have noticed....I do need to get another one, mine was trashed after hitting a dead animal. This happened last night and i haven't removed it, looks like hammered horse s**t!!
Old Oct 23, 2005 | 07:33 AM
chuckb's Avatar
chuckb
I hate re-kills
I would just buy another one. it's there to keep dirt, water, debris etc. away from your motor, aswell as aerodynamics I'm sure.
drive temporarily without it if you want, but I wouldn't leave it that way.
Old Oct 23, 2005 | 08:56 AM
TLW's Avatar
TLW
I drove without mine for a while ..but i wouldnt do it permanently
Old Oct 23, 2005 | 02:35 PM
GWELEX's Avatar
GWELEX
I had read that it is very important for proper engine cooling. Get a new one or hammer your back into better shape.
Old Oct 23, 2005 | 02:49 PM
Ronsully's Avatar
Ronsully
you don't need it. I drove my supra around without the under engine cover for over 3 yrs. In fact, I think it it better to not have it as you will be able to see any fluid leaks right away. BTW, your engine won't get any dirtier.
Old Oct 23, 2005 | 11:18 PM
rominl's Avatar
rominl
exclusive matchup
lower engine cover? the big plastic cover that's under the front of teh car? it's ok to take it off. my friend has been running without it forever
Old Oct 23, 2005 | 11:59 PM
salimshah's Avatar
salimshah
25 Year Member
Other members have found it that it is not essential. Is it redundant? If so why would the manufacturer spend money and time installing one?
My view has been, if it is there, there is a reason. [ A lesson learnt many years ago when a metal plate was removed on a vw bug near fuel filter. The metal plate was a heat deflector and once removed the fuel line suffered from vapor lock, but only after 15 or 20 minutes from cold start]]
Without the plastic bottom, you would definately change the air flow pattern inside the engine compartment.
Salim
Old Oct 24, 2005 | 12:04 AM
rominl's Avatar
rominl
exclusive matchup
i wouldn't say it's useless. it's probably there for
1) aerodynamic
2) avoid dust
3) avoid possible road debri
but it's not like your car will stall without it
Old Oct 24, 2005 | 12:11 AM
RMMGS4's Avatar
RMMGS4
Northern California Regional Officer
1) aerodynamic
2) avoid dust
Like Rom said, it's mainly aero. Lower Coefficient of drag = better gas milage.
Haven't had one on my car for 5 years.
Fix it if you can, but it's nothing to loose sleep over.
Old Oct 24, 2005 | 07:24 AM
Ronsully's Avatar
Ronsully
I guess it helps the aerodynamics a tiny bit. However, don't confuse the under engine cover with skinning the underside of the car.
Old Oct 24, 2005 | 07:30 AM
sockfocks's Avatar
sockfocks
well guess what....its been removed and I gained 10HP AT THE WHEELS...imagine that!
LOL jk thanks for the info guys...
TCM55
IS F (2008-2014)
Jun 3, 2021 12:28 AM
Meraki Autoworks
IS F (2008-2014)
Jan 19, 2012 07:31 PM
jaxxx
Jan 6, 2011 01:28 PM
SC3coupe
Jul 7, 2010 04:38 PM
