Spoiler Install
Does anyone have the templete for a spoiler install of a 2nd Generation GS? It would be for the OEM spoiler. Thanks in advanced
https://www.clublexus.com/forums/sho...oiler+template
yeah, i figured I would need to go to the dealership and get it there
Oh well, Thanks
The OEM spoiler installation is probably different than most aftermarket spoilers, and will require you to drill special holes.
The holes cannot be reached from the inside of the trunk ...
You should of gotten brackets that screw into the spolier?correct?
screw them into the spolier(to the 2 holes on the spolier),
put 3m tape on the back side of the bracket,
once that is done just place the spoiler on the truck ,
once you have it lined up push down on the spolier just to make sure the 3m tape sticks,
now you can remove those 2 screws so that all you will have on your trunk is the 2 brackets all lined up
then make your holes in your trunk while the brackets all still in place
this is how i did mine, took about 1/2 very easy
If you dont have those brackets connect steve and he will get them for ya
check out this thread https://www.clublexus.com/forums/sho...5&pagenumber=1
it has the part sheet w/part numbers on page 2
How's the installation? Is that a easy 1/2hr job?
Did you order screws and brackets to do the installation? Is the brake light just plug n play with exist harness?
Glad your spoiler came out great. I'm still looking for one.
