How do I know if my shocks/struts are worn out?
Old 08-27-03, 10:48 PM
DroppedGS
DroppedGS's Avatar
Default How do I know if my shocks/struts are worn out?
My car seems to ride a bit ruff over bumps. But this is how the car drove before I brought the car so Im not sure how the car is suppose to really ride..
Whats the easiest way to tell if my shocks/strut or springs are worn out??
Old 08-27-03, 10:52 PM
LB Lex
LB Lex's Avatar
The easiest and least scientific why is the "Jump on the car and see how many times it bounces" test. The car should not bounce more than two/three times after you push the bumpers up and down. I bet you've seen cars with broken shocks before but haven't noticed it, a car will bounce 5-6 times after going through a dip.
Old 08-29-03, 06:57 PM
DroppedGS
DroppedGS's Avatar
Default Thanks
Thanks Alot For The Help!
Old 11-24-03, 01:23 PM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Besides the uncomfortable ride, is there a hazard in driving with worn out struts? (just wonderin).
Old 11-24-03, 03:56 PM
Pianoman72
Pianoman72's Avatar
Nothing keeps the springs in check and your car just lurches front-back front-back when you hit the brakes. Drove a U-haul like this and it is scary.
Old 11-24-03, 04:18 PM
LB Lex
LB Lex's Avatar
Your car also won't handle as well because it will be leaning to the side because of the worn shocks.
GreatRX300
RX - 1st Gen (1999-2003)
01-21-18 12:27 PM
Cbb129
Suspension and Brakes
02-06-17 04:08 AM
dbtbee
28
06-22-16 11:32 PM
kpkim01
SC- 1st Gen (1992-2000)
08-15-10 01:15 AM
kevin.tran
07-17-08 06:07 PM
Quick Reply: How do I know if my shocks/struts are worn out?
