Almost Crashed Need Help
Old Jul 28, 2011 | 09:16 PM
Supremeg56's Avatar
Supremeg56
Unhappy Almost Crashed Need Help
So I'm driving to work cruising doing like 90mph in the express lane when traffic starts to slow me down so i hit the brakes and I'm getting closer to the car when all of a sudden my brake pedal gets hard and I'm not slowing down at all so at this point I'm like scared as hell I'm about to crash then the brakes get normal and I skid about an inch away from the car ahead of me I'm sitting in the car like WTF just happened
At that time 3 lights came on on the dashboard
Uploaded with ImageShack.us they are ABS, TRAC and TRACS OFF
I ran a scan with a OBD 2 scanner but no codes pop up I was wondering if anyone had this problem before and can somewhat help me single it out I drove it home and nothing was wrong then the lights came on again leaving later on that night but my brakes were still working fine I'm thinkning its a master cylinder or the ABS pump but I'm just a rookie at these things
Any help would be appreciated
Old Jul 29, 2011 | 04:47 PM
ReeM's Avatar
ReeM
Wow bro. 1. Im glad you alright and 2. I never heard or experienced anything like that.
I stepped on the brake hard once cause a car stopped short and they didnt do much. The stock brakes suck :'( I was about 1 foot away from bashing the car. smh
Old Jul 29, 2011 | 04:50 PM
1sWt2GS's Avatar
1sWt2GS
first gen GS are scary
im glad your fine, hopefully someone with some insight can help you out
Old Jul 29, 2011 | 06:06 PM
deknick's Avatar
deknick
the car (atleast 1gen aristo's) isn't OBD2, so that might be why the scan came up with nothing.
those 3 lights are signs of a shot brake master cylinder. have a look at your BMC, and monitor your levels.
if the pedal got really hard to push, then easy to push again, that seems like it would be the BMC or nitrogen accumulator (if you have one in the GS300's, i'm not sure about them)
Old Aug 2, 2011 | 04:32 PM
Diemellz's Avatar
Diemellz
aleast u get to stop n alright, sometimes, mines just cut off
Old Aug 2, 2011 | 10:06 PM
poplatino4's Avatar
poplatino4
Even a OBD-II scanner wont popup ABS or TRAC codes on most OBD-II Toyotas or Lexuseseseseseses (i call plural lexus lexi) . Either its manual code retrieval or use the NISS-1 diagnostics connector on the intake.
Old Aug 2, 2011 | 11:36 PM
deknick's Avatar
deknick
have you tried to jump the diagnoses port and get a code?
Old Aug 3, 2011 | 07:38 AM
Hert's Avatar
Hert
97's were obdII
Old Aug 5, 2011 | 08:41 PM
Supremeg56's Avatar
Supremeg56
what do you mean by jump diagnoses port the one under the hood is all messed up so the only port I can connect to is the one inside the car under the driver side dash
Old Aug 6, 2011 | 10:59 AM
poplatino4's Avatar
poplatino4
Here you go. just for you.
Old Aug 6, 2011 | 11:40 AM
poplatino4's Avatar
poplatino4
Trac......
Old Aug 8, 2011 | 04:04 AM
Supremeg56's Avatar
Supremeg56
Thanks for that info clublexus is coming through in the clutch I'll try it out this weekend when I get some free time but oddly enough the lights or the problem hasn't happened since I'm going to change my rotors and brakes since that causes some vibration as well the car seems to be running and braking normal but anyway thanks poplatino4 and deknick for the info it's appreciated
Old Aug 8, 2011 | 10:06 PM
deknick's Avatar
deknick
one of the benefits of being on clubaristo.net, would be the following thread
http://clubaristo.net/forums/showthr...ght=paper+clip
newgsman
Feb 12, 2015 11:32 AM
Supremeg56
Florida Lexus Club
Jul 31, 2011 10:27 PM
mtm864
Jul 18, 2010 05:39 PM
Asha'man
Sep 3, 2009 05:51 PM
CCC-TT
Aug 10, 2007 12:13 PM
