Disc Brake Problem
Old Dec 15, 2008 | 10:49 PM
ozzie's Avatar
ozzie
Default Disc Brake Problem
I just changed my front pads on my '93 GS 300 and on the driver side it appears that one of the floating sleeves that the caliper bolts to has seized. It caused the old pads to wear unevenly and the new pads are to tight and binding.
The sleeve is on the bracket that bolts to the spindle. Is this part available or can I have the bracket rebuilt?
Any help appreciated,
Old Dec 16, 2008 | 09:25 AM
boxcarfan's Avatar
boxcarfan
i had my pass. side cailper seize up on me and when i bought a new one (aftermarket) it came with new slide pins...check like autozone or somewhere and see if you can buy just the pins.
Old Dec 17, 2008 | 06:52 AM
mad_trbo's Avatar
mad_trbo
Default New Caliper
I think you are going to need a new caliper.
Do you have a pull apart in your local area. You can probably find a gs300 with calipers and pull what you need.
Can you get the pin out of the current caliper?
Old Dec 17, 2008 | 08:29 PM
ozzie's Avatar
ozzie
I got a rebuilt caliper & bracket assembly for $62 from my local auto supply. I was going to hit the junkyard or try to repair the old one but at that price it wasn't worth the hassle.
Thanks
Pzindy
RX - 1st Gen (1999-2003)
Jul 28, 2017 10:01 PM
New97ES300
Nov 3, 2013 04:16 PM
lyoooha
Feb 7, 2013 10:42 AM
thejanitor
Apr 14, 2012 06:28 PM
Lex*Toy
Suspension and Brakes
Mar 22, 2007 08:05 PM
