New Owner here!
Old Nov 2, 2013 | 04:59 PM
New97ES300's Avatar
New97ES300
Default New Owner here!
Hi everyone! i have recently become a new owner of a 1997 Lexus Es300! The car has a few problems, which i kind of expected for a 16 year old vehicle, but I'm excited to tackle them and also learn a thing or two!
I took it into a mechanic recently and they said i needed a:
1) Tune Up
2) Rear Brake Pads
3) Fuel Filter
Is there any advice i could get on doing these projects
I attempted the brake pads yesterday as i did a search on this forum and there was a step by step. I ran into a problem with getting the caliper off because i either didn't have the clearance from my socket, or the bolt was just locked in place. Im a big guy (230 lbs) and i couldn't get the top bolt of the caliper off to save my life.
Thanks!
Also, i swung the caliper up after removing the 12mm bolt from the back. I put the new brake pads in after pushing the piston back. when i put the caliper back down, there was not enough room.. the 12mm bolt hole wouldn't line back up and was hitting the part that held the pads in place. Has anyone else encountered this?
Old Nov 3, 2013 | 03:17 AM
Hayk's Avatar
Hayk
Your caliper bolts are seized up. They are supposed to allow the caliper to slide. I had the same clearance issue, and I fixed it by tapping the bottom caliper bolt out and lubing it up.
Old Nov 3, 2013 | 03:33 PM
New97ES300's Avatar
New97ES300
ok, i felt that they may have been. i used some penetrating to lube today to see of that might do the trick. (it didn't) What do you mean by tapping the bolt out?
Old Nov 3, 2013 | 04:16 PM
Hayk's Avatar
Hayk
The bottom bolts can be completely removed out of the caliper. I used a punch and a hammer to get it out.
Pablorock
Aug 25, 2016 02:14 PM
elacesar
RX - 1st Gen (1999-2003)
12
Sep 4, 2009 07:13 AM
Mike813
Suspension and Brakes
May 22, 2008 10:47 AM
wallcloud
Dec 16, 2006 05:05 PM
heyma
Mar 25, 2003 11:03 PM
