Florida Lexus Club The place for Florida Lexus enthusiasts
Tech support post your question here...
Old Oct 1, 2009 | 07:05 AM
  #76
DINH300's Avatar
DINH300
Originally Posted by YeA 2jZ
thanks for the response how long would you say it is safe to drive like this and what size HG to I get ? I want something thicker than stock but not that big thats it drops my compression so low. I am going to go with a 61mm or 67mm turbo btw
I have driven it a 2mm HG for over 6 months without boost the car felt much slower. Probably a 1.5 or 2mm would be good, remember the thicker the headgasket the more sluggish your car will get when you drive without boost.
Old Oct 1, 2009 | 07:32 AM
  #77
//LRD's Avatar
//LRD
ok i got one i am peiceing together my turbo kit but not ready to install it yet BUT i need to do some maintenance first on my GE. So my question is since I am going to change Timeing belt and water pump and front seals can I also install a thicker HG and run the stock engine without any problems for a while. Basically want to install the ARP studs and thicker HG and still be stock is thats ok or would I have to put on the HG and Studs when I do the turbo install
If I'm not mistaken you could run the ticker HG now.But the car is going to feel extremely slow .
Old Oct 1, 2009 | 08:00 AM
  #78
YeA 2jZ's Avatar
YeA 2jZ
extremely slow ??? i mean it slow now
Old Oct 1, 2009 | 08:24 PM
  #79
98$c300's Avatar
98$c300
Dude i dont know how much you looking to spend.but from what i have learned.if you gonna open your motor.why dont you throw GTE pistons and rods?then you can use a stock GTE headgasket.just my .o2cents.
Old Oct 2, 2009 | 05:52 AM
  #80
SH_JZZ30's Avatar
SH_JZZ30
Changing the head gasket is not really opening the motor. And the stock ge block is strong.
Old Oct 2, 2009 | 06:16 AM
  #81
YeA 2jZ's Avatar
YeA 2jZ
i am pulling the head for studs and new HG block is fine no need to pull engine and i can run GTE headgasket now if i want.
Old Oct 2, 2009 | 03:11 PM
  #82
blk&blu*j's Avatar
blk&blu*j
I would highly recommend that you do a compression test before you start spending money on the necessary parts so you'll have a base line to work from and if you have bad or low compression in any cylinders you can address the issue while the head is off!!!
Old Oct 2, 2009 | 04:32 PM
  #83
98$c300's Avatar
98$c300
This is how I look at it.you planning to pull the head.you gonna have to one day pull the oil plan to tap the oil return from the turbo.that's why I said to swap out the pistons and rings and rods.then you know for sure you block is bling-bling.
Old Oct 2, 2009 | 04:47 PM
  #84
Punky's Avatar
Punky
Wow Sir, you sound like Mr. Lexforlife... A lot!
Old Oct 2, 2009 | 05:07 PM
  #85
98$c300's Avatar
98$c300
I listen and learn and take in 411 like a sponge.lol
Old Oct 2, 2009 | 06:37 PM
  #86
Wicked SC's Avatar
Wicked SC
Damn Punky, that was a good one!!!
Old Oct 2, 2009 | 07:52 PM
  #87
Punky's Avatar
Punky
Ok guys I have two questions.
1. How much tire PSI for my aftermarket wheels/tires is good to use?
2nd. Can someone give me info on how a remote bottle opener works?
Old Oct 2, 2009 | 08:17 PM
  #88
YeA 2jZ's Avatar
YeA 2jZ
I have another block that will be getting built just wanna boost what I have now to get going.......
blk&blu*j thanks for the advice I will get this engine compresion tested it's at 110k so well see
Old Oct 2, 2009 | 11:09 PM
  #89
98$c300's Avatar
98$c300
on your second ?.i had one before.all it is,you can have the bottle open all the time.and you have switch to open and close the bottle.
Old Oct 2, 2009 | 11:11 PM
  #90
98$c300's Avatar
98$c300
lol,hey i learning...
