Rim Restore/Repaint
Any ideas on how I could prep them for paint other than sandblast?
Here are the pictures of my rims from my 2000 Lexus ES300
Also, I have read about using a Zinc Chromate Primer instead of a Self-Etching primer. Which is better?
Or should I just sand the damaged spots and feather the edges of the good parts of the wheel, then prime and paint the wheel?
Like L2K said, work up to 400, and then wash, degrease, wash and degrease again. Your results will be based on the time you put into prep so figure A LOT. I have refinished a number of various metal items and one trick I have learned is to do an acid etch of the surface before to promote adehesion on a surface that sees rough use or exposure (like a wheel). Muriatic or phosphoric acid is cheap and effective.
Even with a sandblaster, all you have saved time on is stripping. You still have to go and do all the sanding, cleaning, prep, etc. Try some aircraft stripper or similar to soften the paint to ease removal. I didn’t watch that video, but on mounted wheels, little 5x7 index cars are perfect for masking around the rim (perhaps it shows that technique).
I live in Ontario, Canada. So something I could find around here would be nice
This will match the silver almost exactly. But remember the face of the wheel is machined (and I think clear coated) so painted the wheels will not look like they did originally. But if prepped properly they will look nice.
It has high reviews so that sounds promising. Another generic paint I have been impressed with the results - Rustoleum Professional High Performance Enamel. It is at most Home Depots and Ace hardwares, is relatively inexpensive, comes in a wide varietty of colors, comes in a decent-sized large can, and has an effective fan nozzle to promote a good spray pattern. I would still clear-coat over it as mentioned, though. Make sure the clearcoat is uv-resistant and so labeled.
Oven cleaner is a good idea. I had to rebuild a transmission not long ago, one exposed to the road and not a FWD car semi-protected by a belly pan. 18 years of PNW water, and leaking oil and ATF made it a real mess. Rite-aid has a “dollar” section and I got five cans of very cheap oven cleaner to clean and strip it before disassembly and rebuilding it. Oven cleaner can be very useful around the garage sometimes.
Thanks, I tried it on a small spot and it's much darker though. Maybe with clear coat and proper prep it will look good though.
