Brake pad changing question!
Old Sep 2, 2009 | 09:17 AM
elacesar's Avatar
elacesar
Default Brake pad changing question!
Hello and this is a great forum.. I am changing the pads on by RX300 cause i hear alot of squeaking and i notice that the factory pads both have metal stabilizers but the new DURALAST Gold pads have only one and i just wanted to make sure that it was okay.. Also i did notice that when I reinstalled the caliper i tightened the bolt all the way down and i can feel a little movement on the caliper no matter how tight the bolt is?? Thanks for any help guys..
Old Sep 2, 2009 | 07:37 PM
Lexmex's Avatar
Lexmex
Do you have a picture of these pads or a link to them?
Old Sep 2, 2009 | 07:58 PM
AlexusAnja's Avatar
AlexusAnja
Don't understand. You removed the caliper to replace the pads? I replaced my pads and I only removed the bottom bolt and "flippped" the caliper up. Pushed in pistons and then replaced pads and slid the caliper back down and tightened the bolt.
Also, not sure what you mean by metal stabilizers...
Old Sep 3, 2009 | 06:16 AM
lexus114's Avatar
lexus114
You didnt lube the sliders or anything else?? I always take mine apart and clean/lube everything.
Old Sep 3, 2009 | 06:40 AM
UNOHOO's Avatar
UNOHOO
those are the same pads i used on the front when i replaced the rotors, heres a link to the DIY and the pic showing the pad, not sure if itll show ya what ya wanna see but here it is
https://www.clublexus.com/forums/rx-...otors-diy.html
Old Sep 3, 2009 | 07:04 AM
lexus114's Avatar
lexus114
Yo Womp,was`sup baby??
Old Sep 3, 2009 | 08:14 AM
elacesar's Avatar
elacesar
I am sorry that i was not specific enough.. The pads fit perfectly i am referring to two metal clips that are on the factory pads.. The new ones have the metal clips only on two of them.. I noticed that on your picture that they are exactly what i have so i will leave them as they are cause they work great.. Thanks alot for all of your help..
Old Sep 3, 2009 | 10:49 AM
UNOHOO's Avatar
UNOHOO
just chillin, been sick all this week whats up with you?
i think he was talking about the shims or whatever theyre called
Old Sep 3, 2009 | 11:14 AM
lexus114's Avatar
lexus114
SSDD,you know what that means right??
Old Sep 3, 2009 | 02:41 PM
AlexusAnja's Avatar
AlexusAnja
If you're talking about the metal pad in the back, those are the shims and you can clean the factory ones and just reuse them. I would say most cheaper aftermarket do not come with replacement shims.... thus the lower cost.
Lexus114, I only lube the pin that I remove. The other pin if it feels free and rolls fine, I don't bother with it. Haven't had trouble thus far over my entire car experience of changing pads.
Old Sep 3, 2009 | 03:27 PM
Lexmex's Avatar
Lexmex
I ran my pads a few times in Mexico without shims and can't say that I noticed too much issue. The Akebonos I have bought on rockauto.com always come with the full kit.
Old Sep 4, 2009 | 04:38 AM
UNOHOO's Avatar
UNOHOO
whats the actual purpose of the shim anyway? doesnt seem to make much sense to me, if it sits snug against the pad and doesnt move then why not just increase the pad size to take up the save volume?
Old Sep 4, 2009 | 07:13 AM
Lexmex's Avatar
Lexmex
Well, there is the other issue, temperature, and as something expands and contracts, especially over time, the shim is there to help alleviate this.
http://auto.howstuffworks.com/auto-p....htm/printable
Pablorock
Aug 25, 2016 02:14 PM
ZeusES300
Mar 10, 2015 10:14 AM
PTCS
Wheels, Tires & Brakes Forum
Nov 15, 2014 07:28 PM
kryolla
Suspension and Brakes
Mar 14, 2010 10:33 PM
keeper15
Jun 24, 2009 08:24 AM
