Potential Transmission issue???
I have a 07 ES350 with 33k. I have been reading on-line that this years model or certain earlier dates of manufacture have problems with the transmission. I have had no tranns issues yet but am I doomed? My manufacture date is 06/2007. Am I outside the window of the earlier model trans problems?
From what I remember, I think you are OK. My car was an early build, leased on 10/1/06. The transmission was replaced in 1/07 with just a few thousand miles on the car. Since the replacement and 47,000 miles later, no issues. I did buy the Lexus Platinum Warranty just before my factory warranty expired just to make sure.
I had an early build (4/06) ES350 that I bought in early May '06. I kept it for nearly 4 years and no problem with the transmission.
As garsarno said, if you haven't had any problem to date, you should be OK
From: Vancouver Island, BC -ex Illinois &Toronto, ON
The transmission flare is quite noticable and isn't something that happens after extended mileage - it will always have been there.
If you've not experienced any issue with your transmission then you're fine. My May '07 now has 93K miles on it and no tranny problems.
I have an 2007 with 52k on it. My tranny is slipping. I have an appt on saturday. I also have a noise that sounds like lifters. My car sounds like a diesel. I just purchased it in December. I have got to say I am rather disappointed. Thank heavens I purchased the extended warranty.
Congratulations on the new car. The engine noise and transmission are common concerns with many '07's. It seems there isn't much that can be done for them. If you do a search here on either issue you will find a lot of information.
I was just searching to see if anyone had encountered this trouble and to my surprised it seems that I am encountering this so called flare.
I have noticed it about 3-4 times in the 2 weeks (plus 1 week in the shop) that I have been driving my car, but only during cold morning driving and around 60km speed.
It seems that the transmission doesn't know whether to shift from 3-4 and there is a slight hesitation.
Kilometres on the car is 80k
So my CPO complaints seems to keep growing....
1-rattle in the front dash-it seems to be coming from driver and passenger side
2-They need to align the car/balance tire vibrates when it hits over 110km/h
3-this 3-4 grear hesitation
I know that there was a TSB for #1 the rattling I think, and not sure if there was a TSB for this #3
Taking her in next weekend which is the last of my 30 days and going to have them look at it.
There is also a TSB for the rattles in the dash. That worked wonders as well.
This is an old one. Dealers may not even honor it anymore. See this old thread. https://www.clublexus.com/forums/es-...0-tsibs-7.html
Below is info from NHTSA
Components: POWER TRAINNHTSA ID Number: 10025163
Manufacturer Communication Number: L-SB-0027-08
Summary
TORQUE CONVERTER SHUDDER ON 2007-2008 LEXUS ES350 AUTOMATIC TRANSMISSION/TRANSAXLE MODEL. *PE
Summary
melon
Nov 17, 2009 03:17 PM
Skeltron
16
May 17, 2007 08:28 PM
