Alternator not charging
Old Jan 30, 2024 | 04:04 PM
burntends's Avatar
burntends
1st Gear
Default Alternator not charging
My alternator is not charging my battery. Battery is just under 2 years old, serpentine belt is fine, checked fuses, I took out the alternator and I got it checked say that is at full health. What else could I be missing?
Car has 170k mileage
Old Jan 30, 2024 | 04:58 PM
spaceballs's Avatar
spaceballs
I would check the clutch on the alternator pulley, it might no longer be engaging and thus although it spins, it doesn't produce current.
How did the shop check the alternator? You should be able to spin the pulley and attach a multimeter to the positive terminal and verify it produces current, then do the same with it installed. If it's producing current at the alternator end, check the battery end as well. If no current there then it's likely a problem with the battery cable.
Joldas
Dec 19, 2019 05:50 AM
Sin1UZFE
Dec 14, 2019 09:58 AM
dontcallme
Oct 14, 2019 07:16 PM
PrisyCrisy
IS - 1st Gen (2001-2005)
Sep 15, 2019 06:19 PM
ceddieb
Sep 9, 2018 12:51 PM
