Starting Problem
Old Jul 6, 2005 | 04:35 PM
electro992's Avatar
electro992
Default Starting Problem
Lately I've been having a problem starting the car - it will just stop cranking before the engine starts. I'll have the key held in the start position, but nothing will be happening. This might happen two or three times, but eventually, it will crank fine and fire right up. I'm not sure if this would be a battery issue, since it seems to get better during subsequent starting attempts. Thanks in advance.
Old Jul 6, 2005 | 04:58 PM
Pheonix's Avatar
Pheonix
Cool
Does it slow down and stop like a weak battery, or just stop cold iin the middle of cranking?
Does it make a sound like the starter motor is still spinning?
Old Jul 6, 2005 | 06:40 PM
electro992's Avatar
electro992
Nope, it just stops completely, no sounds whatsoever.
Old Jul 6, 2005 | 07:14 PM
Pheonix's Avatar
Pheonix
Cool
Sounds like a bad solenoid.
I would think the ignition switch is still good.
Old Jul 6, 2005 | 09:13 PM
electro992's Avatar
electro992
Hey Phoenix, thanks for your help.
Any idea how involved replacing the solenoid is? About how much should I be expecting to shell out?
Old Jul 6, 2005 | 10:20 PM
Pheonix's Avatar
Pheonix
Cool
They're built into the starters. (so you replace the starter)
If you run to an autoparts store they go about $75 or so.
CathyP
May 8, 2017 01:19 PM
Alexbenz
Feb 6, 2012 11:49 PM
Fredrico55
RX - 1st Gen (1999-2003)
13
May 3, 2011 09:47 PM
UTGS400
Maintenance
May 12, 2005 06:58 AM
LB Lex
GS - 1st Gen (1993-1997)
Jul 17, 2003 12:12 AM
