Power Steering Pump Whining
Old Feb 2, 2012 | 03:23 PM
worldforgo's Avatar
worldforgo
Default Power Steering Pump Whining
Hello All,
Recently my Power Steering pump in my 94 E300 started whining consistently. Before you say it there is more then plenty of fluid and it looks clean.
I am assuming my Pump is gone with the wind? How much of a pain in the butt is this to replace?
Old Feb 2, 2012 | 03:52 PM
mdbrown's Avatar
mdbrown
Might be a good idea to take the cap off the pump and watch the fluid while the pump is under load. If you see alot of bubbling then the problem is the pump is cavitating which could be a pinhole somewhere in one of the lines.
Old Feb 2, 2012 | 04:02 PM
GS4_Fiend's Avatar
GS4_Fiend
It's common on these cars power steering always leaks. It' whining cuz it's low on fluid or the pump itself is defective.
Old Feb 2, 2012 | 04:16 PM
EEngineer's Avatar
EEngineer
if its whining the bearing is gone. check for bubbles if there isnt any the. just order an rebuilt ps pump
Old Feb 2, 2012 | 04:18 PM
worldforgo's Avatar
worldforgo
Thanks team!
Old Feb 2, 2012 | 06:54 PM
pacheco308's Avatar
pacheco308
question i have noticed my power steering pump whining but when i take the cap off the reservoir it bubbles should i replace just the pump or should i be looking to buy the hoses with it
Old Feb 2, 2012 | 07:01 PM
mdbrown's Avatar
mdbrown
Bleed the air out of the system...
Old Feb 2, 2012 | 07:05 PM
pacheco308's Avatar
pacheco308
OK mdbrown i will make sure to do that tomorrow morning and post my results is there any one who was done this and fix the bubbling problem
Old Feb 4, 2012 | 09:47 PM
pacheco308's Avatar
pacheco308
so finally had a chance to bleed the system did that and still nothing so i decided to have a look while a did the oil change and the power steering pump was soaked with ps steering fluid so i am searing for a new pump and possibly a few of the hoses to wanna take one step at a time.
Tmhender82
Feb 3, 2026 12:37 AM
rick1987
Sep 6, 2015 07:05 PM
sabbates
GS - 1st Gen (1993-1997)
Mar 26, 2014 06:09 PM
dubstar
IS - 1st Gen (2001-2005)
Jun 17, 2011 04:29 PM
ozzie
Apr 29, 2006 09:41 PM
