1000 HP common engine builds
1000hp+ is becoming very common and many recipes are widespread these days.....anyone have a favorite one? I'm torn between an LS or German TTV8
https://www.motortrend.com/how-to/10...rans-swap/amp/
https://www.cpgnation.com/the-1000-h...urbo-ls-power/
https://www.motortrend.com/how-to/18...ls-engine/amp/
https://ls1tech.com/forums/forced-in...k-hp-ls-2.html
The stock internals ford 7.3 is also turning out to be insane
https://www.musclecarsandtrucks.com/...-mostly-stock/
Or you can also go with the bigger engines in V10/12 land but those have been doing 1k+ since 2010
1000 rwhp? It’s seems like the standard formula only requires of few common ingredients; E85, Methanol, and plenty of boost combined with plenty of proven engines, and you can at least make 1000hp or more. The life expectancy varies on engine design, but even one of the most common engines on the road, the mighty Honda K20, a 2.0L, can be your starting point. The high octane E85 is great at resisting knock, the methanol also cools the combustion temps both are critical when your big turbo is going to be forcing 40-50-even-60 psi into the engine. And with all the advancements in fuel and ignition management systems, seems like 1000 hp is the starting point if you want to be competitive in any streetable racing series the require competitors to drive from track to track.
1000rwhp is a bit more than I had in mind, I was more in the 800-850rwhp range since 1000 crank is more easily comprehended than 1200
No to mention a 3600lb car making 800 wheel is gonna smack around a 5k car making 800 wheel.....
Same sentiment here. I come from over 30 years of ICE, and will always love and respect that platform. The evolution of the ICE from the 80's when I first started driving till now has always amazed me. I see EV as just another evolution of the auto. I would actually hold on to my IS350, but the problem is it will be taking up space, I'll still have to insure and register it, and this platform doesn't do well sitting, it needs to be revved out to keep it happy. I would rather pass it on to someone else who will enjoy it
I just can't come to grips with a platform that is what it is unless you are willing to risk arcing the motors or blowing up cells. I don't have an issue working on them, they are actually very easy but they just are what they are. There is no making one 7x faster than it was stock.
I'll probably grow out of it, lord knows I already drive an LS460 as a daily lol!
For some cars it's very expensive to get 1000hp and when you do get there, if it is RWD it is very hard to put the power down. On my GTR to get to that level you have to build the engine and the transmission and it is very expensive, bare minimum $50k and even then it can be tempermental. Same my old Viper, nice big engine but since they didn't make that many of them it costs a lot to get to 1000hp and best way is to twin turbo it. One other thing I personally don't care for is running E85 or race gas. If I want 1000hp I want to build my car to get there using 93 octane because I want to run those hp numbers day in/day out without going to get special fuel. Probably the cheapest way is to get an old Mustang and modify the heck out of it.
Guys with the old fox bodies can cheat since they are so light that 600 hp is like a 1000. As far as fuel is concerned most these days run sensors to set power level in accordance with octane automatically. 93 is easily done for the most part
The GTR is known to be very picky at high power, how did your transmission hold up?
Most local to me use an LS or 5.0, costs $7k if you don't care about it living or 20k if you do, car to put it in ranges from 20-30k.
