A Refueling Tip That Can Help Save Your Paint
Modern urethane paint and 2K clearcoat is chemical resistant and gasoline spills should not ruin your paint job. Don't wipe it off with a paper towel either as it will just scratch your clearcoat. Just dab it and let it soak if you don't have anything else, having a microfiber rag with some water/opimum no rinse in the car would be the best solution. That car looks older that has the paint damage, most likely it has no clearcoat or a bad/single stage clearcoat and it was sprayed with a lacquer or acrylic paint which is why it is not chemical resistant.
If you do get light (surface) scratches, SCRATCH-OUT (which I've recommended on Car Chat many times) will go through them like butter.
