Toyota's legendary V8 has a problem
Old Sep 13, 2024 | 10:34 AM
  #226
Originally Posted by AJT123
I'm good with stuff like this anyway, always getting low prices... But yeah, the cars are crazy how cheap I get them sometimes.
I still can't believe how cheap I got the Mercedes, they could have sold it for double. I've had it practically 2 years and nothing big has gone wrong (just age related stuff like mounts), it's a golden goose creampuff. Runs and drives like it's brand new. He just didn't know what he had. I didn't tell him what he had, but I called every single day while it was waiting on a part for the top and not available yet. Said top has worked flawlessly knock on wood for almost 2 years, and we use it a lot.
The LS430, yeah. Got that 17 grand worth.
The LX I got for $500 over what my friend paid, used my broker buddy for that one. Impossibly cheap we got that for.
haha. I love it. I still remember “tow pig”
Old Sep 13, 2024 | 10:37 AM
  #227
Lol I'm glad it amuses you --- I can't believe you've never heard that.
JDR uses his 5.7 Tundra as a tow pig with his big heavy camper.
Old Sep 13, 2024 | 10:40 AM
  #228
You didn’t know, but the VVT stuff was not on the original 2UZ. Mine doesn’t have it. Too much stuff on the 4.6 to go wrong and it sucked that Toyota never did any updates to the 4.6. Not one on the GX460 in 13 or 14 years
my mechanic recently removed one of my cats.
Down to two now.
And yet I see less overall issues with the UR.....the only real thing they have is HPFP oil gasket leaks and oil burning if the owners drive too gentle.
Old Sep 13, 2024 | 10:43 AM
  #229
The 1UR suffers from oil consumption problems. Maybe because Toyota uses 0W20 and expanded the service intervals to 10K. Overall there is more to go wrong which is the big issue. Sometimes the hydraulic chain tensioner fails, loosening the timing chain tension. In the early years of production, the engine was equipped with too thin unreliable valve springs
2UZ at least got some updates (I don’t agree with them) unlike the 1UR which Toyota left for 18 years untouched
Old Sep 13, 2024 | 10:47 AM
  #230
It's actually because people are scared of redline and using the power, I've yet to have a single one persist even when they are as bad a a quart every 300-400 miles. The less severe cases can literally be as easy as a few max power runs back to back
Valve springs were all recalled by now so that's immaterial.
Chain tensioner doesn't fail, it leaks down at the secondary tensioners for the cam to cam chains and only causes a slight start up rattle. No long term damage or issue except annoyance unlike the UZ blowing out its cam seals and soaking the belt in oil.
Also I'm not sure why you care so much about having a timing belt in a non-VVT version. You can snap it without killing valves.
The UR makes over 100 hp more than the UZ and gets better mpg doing it, breaks less, is easier to work on and having owned both there is no comparison. How many URs have you owned?
Old Sep 13, 2024 | 10:51 AM
  #231
2UZ is interference. You didn’t know that? The 1UR in the GX does not make more than 100HP over the 2UZ. It’s closer to 30HP need the end. Toyota never updated the 1UR in the GX. Left it with 300HP for over 15 years
Old Sep 13, 2024 | 11:19 AM
  #232
That's comical, in what ways exactly?
because jill has the 4.7 so it must be better
Old Sep 13, 2024 | 11:23 AM
  #233
AMIRZA786's Avatar
AMIRZA786
I warned him. Rabbit hole ahead 🤣
Old Sep 13, 2024 | 11:26 AM
  #234
. The older Toyota stuff is better than the newer stuff.
Your 2UR was never updated …it’s the same as it was in 2006. Where is the innovation? At least with the 2UZ it was updated mid cycle. (Even though the stuff they added is not cool in my books)
Old Sep 13, 2024 | 11:48 AM
  #235
You're against VVT-I? It really livened at least the LX570 up. I too love the 2UZ but it's not exactly bursting with power. I blew a first gen Sequoyiah away with the UZ in my old 5.3 Yukon, not even close.
  #236
geko29's Avatar
geko29
You are 80% incorrect. 2UZ was non-interference for most of its run. So for the LX specifically, that's model years 1998-2005. The 2006-2007 had the revised version with VVTi, which IS interference.
Old Sep 13, 2024 | 11:50 AM
  #237
2UZ has always been an interference motor
Old Sep 13, 2024 | 11:59 AM
  #238
FrankReynoldsCPA's Avatar
FrankReynoldsCPA
A 20 year old Toyota engine is too modern?
Old Sep 13, 2024 | 12:00 PM
  #239
geko29's Avatar
geko29
I should have been more clear. Toyota's documentation states that, but there are literally hundreds of cases of pre-VVT engines that have snapped their belts (often at highway speeds) and suffered no damage. Here's just one example:
Every "forcible valve re-clearancing" failure I've ever heard of has been on a VVTi motor.
Old Sep 13, 2024 | 12:05 PM
  #240
The non VVTI UZ engines are not interference.
The 1UR-FSE engine makes 381-387hp
