If your house doesn't have ground connected to neutral at the panel then you need to do something about that. Dunno about in some areas but here (and everywhere else I've lived) that is code.
I honestly would be very reluctant to plug into a NEMA 10-30, anything other than a dryer or Range without using a splitter and the EV (or charging adapter) using no more than 24 amp. Also as stated earlier, 10-30 is not really designed for constant plugging and unplugging, another reason to use a splitter
Why would a splitter improve safety? If anything it would decrease safety IMHO. We're not talking about doing this all the time, this would be done twice a year.
The problem with older houses, chances of them being up to code is remote. When we bought our house, they remodelled but slapped the old panel back on and didn't do it properly. I only found out because when I went solar, they had to inspect the panel and wiring. They had to change the panel, and luckily the cost didn't come out of my pocket and was paid for by state subsidies. The electrician told me it could have caught fire. Previous to getting the new panel installed, the kitchen fuse used to trip all the time if we ran the dishwasher and used an outside plug for say vacuuming our cars
The splitter would make it safer because you would for one thing, not be plugging or unplugging the dryer/charger to charge. Secondly, the splitter only lets you use one circuit at a time. You would not be able to charge and use the dryer at the same time. One or the other. In fact the splitter the electrician proposed to me had a physical switch I had to manually change when charging, than I would switch it back to send power to our washer/dryers. I just ended up putting in a 240v 50 amp that he hard wired the charger into
There is no safety concern because under no scenario will there be a shock hazard from touching the car. It doesn't make a lick of difference how a particular outset is wired, how degraded the house wiring may be or anything else. Power into the car goes through an AC to AC converter then ultimately is converted to DC. It is completely isolated. The claim is if only one wire for example is connected to the car this will make the chassis live. Honestly this is so preposterous I don't even know what to say.
Splitter is good in preventing you accidentally overloading the circuit. I should really get one (I use a welder on the same circuit) worst case the breaker trips. That's why it is there.
Many old homes are a fire waiting to happen, and they do sadly. But this isn't the fault of the car.
Power going into the charge port is filtered, converted, then converted again this is not like plugging in a toaster. I'm confident there are numerous checks to make sure NO power goes into the vehicle chassis to say so is fear mongering I question why anyone would do that.
What's good for the goose is good for the gander. Please provide the source that makes you "confident" that "ground" is not connected to the vehicle chassis during charging as required by code. I posted another link above of a current statement from a charger manufacturer above that is live TODAY in 2023, not in 2014.
Bolded is true. The house (or outlet) could catch fire though if the circuit fuse doesn't pop. Before I got the 240v charging circuit put in, I used to blow the fuses all the time. Also once I had the amps set to high and the extension cord got really hot . In the early days, I had no choice but to use an extension cord, so I got a 10 gauge with a 15 amp fuse
Tesla does not publish any detailed schematics to my knowledge, so I can't "prove" anything. So how about this, you're right and I'm wrong people are getting shocked charging their EVs. This must be happening because the vehicle is "grounded" and you'll get zapped if the outlet is not wired correctly.
If the dryer is unplugged, then it can't be operated at the same time as the car is charging...because its unplugged.
I would still need to plug the charger into the splitter when I charge because the charger will come with me and leave with me...so plugging and unplugging would happen anyways.
I totally agree the splitter is worthwhile if I was setting this up as a permanent solution but its just for when I'm there charging...
No, I got it, you only would be using it once or twice year. I was only mentioning the splitter because you would never have to unplug the dryer again. For some, you have to move the washer/dryer to get to the plug. If that's not the case than you don't need a splitter
I never said it was common. People getting electrocuted by their dryers isn't common either. But it is a modest risk (extremely low likelihood, catastrophic severity), and one that can be easily and cheaply mitigated against by having a real ground.
I couldn't find Tesla schematics either. Best illustration I found was
of a different charger. When he flips the board over, you can see that the input ground wire and output ground wire are directly connected via the PCB. The relays only switch the two hot lines. This is what I'd expect. I don't think I've ever seen a switched ground in an electronic device. They're supposed to be connected at all times, no matter what the state of the circuit is.
Did you watch the video? Even that inexpensive cable has safety features including differential voltage protection. Meaning any unintended load results in power cut. Only way an EV shocks you is if it has no protections at all. Just dumb wiring like a drier from 1982.
