Level 2 Charging at a house as a guest
Best thing, if possible, is to DCFC up to 80% somewhere near your brother's and use the L2 to top up to 100%. That would take you maybe 4 to 5 hours or so.
That's another alternative if you can find an RV park or something with 30 or 50 amp plugs nearby, might be able to park your car there and pay the owner a bit to charge up. example https://www.goodsam.com/campgrounds-...cgid=202322622
That's another alternative if you can find an RV park or something with 30 or 50 amp plugs, might be able to park your car there and pay the owner a bit to charge up.
I never thought of that! There are all kinds of camping areas and RV parking areas etc, and my cousin knows the owners of many of the rafting outfits...thats a great idea.
10-30s were banned in 1995 because they're unsafe (because there's no ground). You don't want a 15-X (I'm not aware of the 15-40 existing, they jump from 15-30 to 15-50) because that's for 3-phase power (Hot/Hot/Hot/Ground). You want a 14-X which is for split-phase 240V (Hot/Hot/Neutral/Ground). Since the current outlet is 30A, it's unlikely that the wiring and breaker are rated for 50A, so it is not ideal to put a 50A rated outlet there.
The 10-30 charger you listed will probably work, with two caveats: 1) Check to make sure it's UL listed, as they usually want a ground in order to grant certification. As of a couple years ago, Tesla was the only one that was UL listed. 2) When charging, the vehicle's body will be connected to the house neutral. If everything is wired correctly, there will be no problems. However, if there is miswiring somewhere in the house, the neutral can become energized. This is the same risk that the dryer (if installed) currently has.
Its not that 10-30 outlets are "unsafe", every house in the world built before 95/96 pretty much has one for the dryer plug, its just that code changed to improve safety, 14-50 outlets are MORE safe.
https://shop.tesla.com/product/universal-wall-connector
Ground is the ultimate safety factor for most kinds of wiring fault. It gives any current leakage an easy return path. When there is no ground, the next easiest path will be used. In many cases, it's the unfortunate bag of meat that touches the energized device that becomes the shortest path to ground. That's why the electrical code was changed sixty years ago to require grounds for all outlets. Except this one, because $$$$.
