Build Threads Details on Club Lexus 2GS owner vehicles
Engine / transmission mounts
Old Feb 8, 2018 | 06:13 PM
3blkgs's Avatar
3blkgs
Default Engine / transmission mounts
I’m currently gathering parts to do an aristo swap and I will also need to change my motor and transmission mounts. I believe the motor mounts won’t change from a regular GS to an aristo, is that correct? Since the JDM transmission is different what mount do use, a regular GS or will it have to be a JDM mount. I tried searching but didn’t find anything.
thanks
Old Feb 9, 2018 | 08:47 AM
Letsride's Avatar
Letsride
All of the mounts are interchangeable between the 2. You can use the GS or aristo mounts.....whichever are in better condition!
Old May 9, 2018 | 07:11 AM
3blkgs's Avatar
3blkgs
well I finally got around to starting my swap and I keep blowing my ALT 120A fuse. I've checked the wire harness for any cuts or bare wires, didn't see anything. Could it be just a bad ground or something with my alternator?
Old May 9, 2018 | 07:24 AM
Letsride's Avatar
Letsride
Thats a sign of a dead short to ground. start by disconnecting the B+ lead at the alternator and check. Then starter etc.....
Old May 9, 2018 | 01:50 PM
3blkgs's Avatar
3blkgs
cool, thanks.
ill double check and see what I find.
BHustle84
Performance
Jun 3, 2019 08:02 PM
DshngDaryl
Jun 30, 2017 12:23 PM
Eds98LS
Mar 30, 2013 08:27 PM
suprandsc
Feb 25, 2012 06:59 PM
Supraownzu
Performance
Nov 3, 2005 08:17 PM
