Build Threads Details on Club Lexus 2IS owner vehicles
Building an IS350 6MT
Old Dec 9, 2015 | 09:59 AM
  #76
kickin8's Avatar
kickin8
2IS/2RX/4RX
*SUPER EXCITED*
Thanks for the update!
Old Dec 9, 2015 | 11:19 AM
  #77
PAVGR's Avatar
PAVGR
So since your car has VDIM you don't need to change any harness incide the cabin?You don't have to take your dashboard off?Everything else is the same?
Old Dec 9, 2015 | 08:19 PM
  #78
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
There are a few things that had to be done inside the cabin as well.
I got the wiring harness almost completely installed before getting the engine back into the car. Still waiting for that fuel line to come in, but it can be installed with the engine in the car (it is holding up installing the intake manifold though). There's definitely a lot less going on in the bay now though!
Jeff
Old Dec 9, 2015 | 09:10 PM
  #79
PAVGR's Avatar
PAVGR
Wooooooohooooooo!!!You really made this swap look very easy Jeff!Bravo again to you my friend!Is it easy for someone to make the wiring by himself ?How can I find all the details of both wiring ?Do you have to change the manual cluster too or it stays?
Congrats again Jeff for doing this
Old Dec 10, 2015 | 07:15 AM
  #80
MIA_LEX's Avatar
MIA_LEX
Man thats awesome. Your going to love those gains. Nice R&D
Old Dec 10, 2015 | 12:54 PM
  #81
PAVGR's Avatar
PAVGR
Do I need the IS350 gearbox and drive shaft and mid shaft for this swap Jeff?Will you keep your diffential or you ll use the 350s?
Old Dec 10, 2015 | 02:31 PM
  #82
mike33's Avatar
mike33
Since he is using the same transmission I think he should be able use the current drive shaft, and I know he has an lsd, so i dont think he would replace the differential.
Old Dec 10, 2015 | 02:37 PM
  #83
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
I'm mostly keeping the IS250 stuff, but I have changed my differential and gearing previously, so it's not quite the same as the IS250 would be. Europe has different parts than we do for the differential as well I believe. I haven't checked extensively.
I did get my hood label installed! It's very exciting, haha, but it is likely all that will happen today. No time!
Jeff
Old Dec 10, 2015 | 06:54 PM
  #84
Bichon's Avatar
Bichon
Jeff
Hey, even with the original motor I hear that sticker is good for at least an extra 5 HP.
Old Dec 11, 2015 | 10:31 AM
  #85
Schweebs's Avatar
Schweebs
Interesting and very good work keep it up
Just wondering if it would it be easier to to swap the is250 MT transmission in a AT is350 or the engine is350 engine in a MT is250 ? Or is it the same amout of work ?
Old Dec 11, 2015 | 10:51 AM
  #86
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Personally I think swapping the engine in an IS250 would be easier than swapping the transmission in an IS350.
Jeff
PS: Stickers always add at LEAST 5hp.
Old Dec 11, 2015 | 12:07 PM
  #87
PAVGR's Avatar
PAVGR
I forgot to tell Danny that In Greece we have LHD cars so he told me that I should get the parts from a USA IS350 then
Keep up Jeff
Old Dec 11, 2015 | 01:48 PM
  #88
Schweebs's Avatar
Schweebs
Jeff
I guess MT transmission has different mounting points as opposed to the is250 engine having same mounting ponts as the is350 engine right ?
Old Dec 11, 2015 | 10:23 PM
  #89
plankton07's Avatar
plankton07
It is indeed much easier to swap the engine in an IS250 manual than to swap the transmission in an IS350 auto. The autos have a different centre cockpit to the manual which you'll have to cut away to make space in the auto. Not 100% sure about the mounting points though... pretty sure they're similar.
  #90
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Correct. The driveline behind the engine is one of the main differences between IS250 MT and IS350 AT, the other being the interior of course.
Trans mounting would likely be okay with the right mount and stuff, but the rear subframe is much different between the two.
Jeff
