Build Threads Details on Club Lexus 2IS owner vehicles
Building an IS350 6MT
Old Dec 12, 2015 | 12:34 AM
  #91
Sh1nra's Avatar
Sh1nra
Subbed! Your making a lot of peoples dreams come true haha!
Will you be inputting the cost and hours put in this swap once its done?
Old Dec 13, 2015 | 06:02 PM
  #92
NYKnick101's Avatar
NYKnick101
hey Jeff, are you gonna do a full write up of everything someone would need to do the swap? doesnt need to be step by step (but would be great) but at least parts list and who we would need to contact to do ECU reprogram
Old Dec 18, 2015 | 08:13 AM
  #93
scott1256c's Avatar
scott1256c
Any updates Jeff? Got that ecu off for programming yet?
Old Dec 28, 2015 | 10:05 AM
  #94
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
No updates yet, no. Was in Hawaii for a bit and then Christmas and now New Years. Slowed progress a bit, lol. I had to order one last hose that I needed and then it should be all mechanically installed. Still need to put the interior back together as well I suppose. Once all that is done I'll get the ECU ready for programming.
Going to order the brakes today though I think. Just deciding which ones to get....
Jeff
Old Dec 28, 2015 | 11:42 AM
  #95
redspencer's Avatar
redspencer
OG Member
Veteran: Marine Corps
Jeff
Since your build demonstrates what OEM swaps are possible on the 2IS platform, perhaps a brake upgrade to the 4th Gen GS350 F-Sport brakes would be a good candidate?
We've talked about the potential of the 4GS350 F-Sport brake swap on the forums before but I'm not sure if anyone has actually made this happen. Perhaps you can do the honors of being the first and also add another unique OEM+ upgrade to your mod list.
Old Dec 28, 2015 | 11:46 AM
  #96
PAVGR's Avatar
PAVGR
Why don't you just install ISF brakes.I believe it's the perfect upgrade for you!
Old Dec 28, 2015 | 01:27 PM
  #97
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The 2-piece 14-inch setup from the RWD GS350/RC350 F-Sport is definitely one of my options and I have a parts list for the conversion on a 2IS, my hesitation is whether or not I want to be forced to run 18" or larger wheels, especially in the winter, and needing to get an alloy spare tire for the aluminum hat. Still, I'm considering it heavily.
IS F brakes likely won't happen.
Jeff
Old Dec 28, 2015 | 05:19 PM
  #98
Gville350's Avatar
Gville350
Yep! https://www.clublexus.com/forums/sus...0-f-sport.html
Still had yet to pull the trigger. Just working on the all-out engine performance at the moment. But here's a deal if you're looking for a slightly used set : http://www.ebay.com/itm/321803572124?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The only thing I've been unable to narrow down is the closeness in design/dimensions is the knuckles on both cars.
Old Dec 28, 2015 | 05:22 PM
  #99
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
The knuckles are very different, as such the backing plates won't work, however IS F ones will likely work in place, they use the same calipers and rotors as the IS350 on non-F-Sport models, so the mounting should be the same as far as that goes.
If they didn't require 18-inch wheels and an alloy spare I'd already have them. :\
Jeff
Old Dec 28, 2015 | 05:24 PM
  #100
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
So I was in Hawaii for a bit over a week on vacation and then Christmas happened, but work is underway again. Engine is basically assembled now, save for a hose. Should hopefully be able to send the ECU for programming next week I hope!
New brakes and a new windshield also going to happen in the next few days as well.
Jeff
Old Dec 28, 2015 | 05:40 PM
  #101
Mike_1GO's Avatar
Mike_1GO
sound generator
Old Dec 29, 2015 | 11:51 AM
  #102
PAVGR's Avatar
PAVGR
Very clean job Jeff.I really envy this build!I can't wait to see it running!
Old Dec 29, 2015 | 07:37 PM
  #103
Jeff Lange's Avatar
Jeff Lange
Keeping it Real
Originally Posted by Mike_1GO
sound generator
Yeah, I actually already had it before, though the pipe had to be replaced for the 2GR.
Jeff
Old Dec 30, 2015 | 12:36 PM
  #104
Gville350's Avatar
Gville350
Nice work!
New windshield? Planned?
Old Dec 30, 2015 | 01:28 PM
  #105
lobuxracer's Avatar
lobuxracer
Tech Resource
https://www.clublexus.com/forums/is-...ld-myself.html
Sounds like this all over again.
