Looking for recommendations on oversize oil filter
Old Jul 21, 2007 | 06:41 PM
hugo2648's Avatar
hugo2648
Default Looking for recommendations on oversize oil filter
I have a new to me 2000 RX300 with 113K miles. I decided to change the oil and went to the Toyota dealer for the filter. I had a couple of questions on oil filters that Iam sure the list members will be able to provide me some guidance on.
1) I asked the Toyota dealer for Part No. 90915-YZZD1. They did not have that in stock. Instead they gave me 90915-YZZG1. They said it is the same. One is made in Japan and the one they gave me is made in USA. Difference is only in "G1" versus "D1". Is that true ? Should I use the filter I bought ?
2) I feed all my cars with synthetic and change at 7,500 mile intervals. For that reason, I have switched all of them to oversized oil filters (Fram PH1). When I saw the size of the filter I bought, I did a double take. It is itsy-bitsy teenie-weenie ! Is there an oversized oil filter that will fit the RX300. What is the number ?
Thanks,
Hugo
84 Mercedes 380SE....99K
99 Dodge Intrepid ES...99K
00 RX300...113K
01 Chrysler Town and Country Ltd...47K
Old Jul 21, 2007 | 06:54 PM
TunedRX300's Avatar
TunedRX300
1) The made in Japan is way better design. I would get my refund and buy NAPA Gold filter because it is more cost effective.
2) I am using FRAM XG 3600, same bypass valve value and diameter as OEM sized 3614, just 1/2 inch longer. If you don't want to use FRAM, try Mobil 1 M209.
Old Jul 21, 2007 | 10:33 PM
thomas1's Avatar
thomas1
The oil filter for the Toyota Tundra and Sequouia is larger and has the same gasket and thread size. It is a little longer....
Old Aug 2, 2007 | 10:14 AM
Lexmex's Avatar
Lexmex
For the K&N, the filter would be HP-2009 rather than the HP-1002.
Old Aug 2, 2007 | 11:37 AM
salimshah's Avatar
salimshah
25 Year Member
As long as the threads and location of the gasket (O ring seal) is correct, it should work. If it was smaller, there might have been issues with the flow rate.
My concern has always been the tight location .. very little wiggle room, specially when I persist on working from the top. Be aware that eventually you will be removing it and you may need a bit of room to put the tool on it and work it loose.
Salim
Old Aug 4, 2007 | 04:40 PM
Lexmex's Avatar
Lexmex
Here is the HP-2009, it is the same 3 inch diameter, but 1.34 inches taller than the HP-1002.
Attached Thumbnails Looking for recommendations on oversize oil filter-img_2884.jpg
Old Aug 4, 2007 | 04:42 PM
Lexmex's Avatar
Lexmex
Its diameter fits perfectly on the engine block.
Attached Thumbnails Looking for recommendations on oversize oil filter-img_2889.jpg
Old Aug 4, 2007 | 04:43 PM
Lexmex's Avatar
Lexmex
A side view.
Attached Thumbnails Looking for recommendations on oversize oil filter-img_2895.jpg
Old Aug 4, 2007 | 04:46 PM
Lexmex's Avatar
Lexmex
It was a little tough to screw one given the space to put a ratchet and extension on the 1 inch nut on top is shorter than that of the HP-1002, but we managed.
BTW, obviously I did an oil change. I am now testing for one cycle, Liqui Moly 5W30 though I still recommend the German Castrol 0W30 if you can get it, but unfortunately it doesn't exist down here anymore.
Attached Thumbnails Looking for recommendations on oversize oil filter-img_2897.jpg
leehom
NX - 1st Gen (2015-2021)
Oct 1, 2022 09:17 AM
hoonami
Maintenance
Jan 1, 2009 09:29 AM
coppedl
Dec 7, 2005 03:16 PM
rockdrop
May 3, 2005 06:22 PM
leong1
Nov 30, 2002 09:10 AM
