2006 LS 430 Low Tire Warning Light
Old Mar 28, 2026 | 10:13 AM
LagunaKim's Avatar
LagunaKim
2nd gear
Exclamation 2006 LS 430 Low Tire Warning Light
This warning light comes on even though the tires are properly inflated, including the spare.
When I take the car to Big 0 tires to be rotated, they first try to tell me that I need new sensors. This model and year does not have sensors on the tires.
After convincing them that they cannot sell me tire sensors, they are able to reset the system so the light goes away.
However, the first time that I drive it on the freeway at speeds 55 mph or higher the light comes back on again.
How can I fix this?
Old Mar 29, 2026 | 05:55 AM
Klugie's Avatar
Klugie
sentence 2 "they first try to tell me that I need new sensors" sentence 3 " This model and year does not have sensors on the tires" You need to be more precise. I, for one, am confused.
Old Mar 29, 2026 | 06:36 AM
alextv's Avatar
alextv
There are no sensors inside tires. It uses a sensor external of tires.
Old Mar 29, 2026 | 06:55 AM
Klugie's Avatar
Klugie
I presumed internal sensors. Thanks for clearing up my confusion.
Old Mar 29, 2026 | 07:09 AM
1ls430ul's Avatar
1ls430ul
2nd gear
Default Explaining the early TPMS
Lexus in their early days used Wheel speed, measured by the ABS system. If you have a tire that is low on pressure, it will need to spin faster to keep up with the car, therefore triggering a light that the system thinks the tire is low on air. If all of your tires are identical in size, and pressured exactly the same, then likely the problem is with the sensor, rather than the tire or wheel. In order to reset it, there is a button underneath the dash that wants the tires are all of the correct pressure and size, you reset the button so the system has a baseline to measure from.
Old Mar 29, 2026 | 07:45 AM
CA2WALS430's Avatar
CA2WALS430
@1ls430ul , good stuff, I didn't know how they worked.
I do know they can be annoying and we mostly got by fine without them, I have one on my RX that is broken and I just don't care. They are a by-product of the Ford-Continental-Firestone lawsuit.
Additionally one thing to note is that temperature and altitude can set them off. When I moved to Utah where we are constantly driving between 4000-7000 ft. in dry air, the dealership warned me in the winter my TPS lights would be falsing on me. It isn't all the time, but he was right, they do occasionally. Then refer to the reset button. If you have the smartkey system, that button is right next to it, so you will need to feel it out or put your camera in selfie mode and point under the dash.
Old Mar 30, 2026 | 01:02 AM
BigBoomer's Avatar
BigBoomer
When you are hitting the Reset button, watch the display and make sure that it says "Initializing" before you let go of the Reset button.
Until it says that you have NOT reset the Tyre Pressure system.
Once reset, it will "learn" the rolling radius of each tyre over the next 50 miles.
If you live somewhere with large temperature changes then you may need to Reset it in Spring or Fall to avoid it being triggered by temperature changes.
Also, if you drive at high altitude for some time it may also need a reset.
Old Mar 30, 2026 | 04:11 AM
Johnhav430's Avatar
Johnhav430
Mine didn't work even when I did have a tire with 16 psi, so dunno what the threshold is, reset properly. Very inconvenient placement of the reset.
Old Mar 31, 2026 | 08:12 AM
BigBoomer's Avatar
BigBoomer
Yeah, the reset button is in an awkward, impossible to see position.
As for why it didn't trigger, I have no idea unless it didn't get set/reset correctly in the first place.
On mine I set all 4 tyres to 32.0psi and then reset the system and went for a leisurely drive to complete the initialisation.
The warning popped up 2 years later and I pulled over immediately. By the time I had gotten out of the car the rear left tyre had completely deflated.
Something had torn a rip in the tread almost 1" long so I was very glad of the TPMS warning.
We never did find what caused it but the tyre was trashed and had to be replaced.
Since then I check my tyres manually twice per year and do the reset after each check.
My Kawasaki 1400 has tyre pressure sensors fitted and it shows the pressure on the dash.
That TPMS system has also save my *** on a couple of occasions, and a flat on a motorcycle is a LOT scarier than in a car.
On that system the standard pressure is 42psi and the TPMS shows the warning when it drops below 32psi.
Old Apr 2, 2026 | 02:08 PM
JffGRY706's Avatar
JffGRY706
not sure about this but
any time the wheels are off the ground the system must be reset
I believe that even if one wheel is raised off the ground the system must be reset
must be reset after tire rotation
Old Apr 2, 2026 | 04:02 PM
BigBoomer's Avatar
BigBoomer
Only needs to be reset when you want the system to learn new tyres or tyre pressures.
Wheel off the ground makes no difference, but if you fit the spare wheel then reset.
The rolling radius of the tyre changes with a change in pressure.
The system learns the rolling radius of the tyre and alerts you when it changes.
Old Apr 2, 2026 | 04:36 PM
funcrusher's Avatar
funcrusher
What if you put aftermarket wheels with tires that are completely different than the stock size?
Old Apr 2, 2026 | 04:57 PM
BigBoomer's Avatar
BigBoomer
Once fitted and at the correct pressure, reset the TPMS and it will learn the new wheels & tyres rolling radius.
Old Apr 3, 2026 | 08:14 AM
funcrusher's Avatar
funcrusher
I need to play with it again because I couldn’t get the warning to stay off the dash for good
LagunaKim
Jan 15, 2026 01:16 PM
Heyhi
May 8, 2024 02:40 AM
andy350
Sep 4, 2013 11:51 AM
ingoodtime
Nov 13, 2011 04:49 PM
Kash
GX - 1st Gen (2003-2009)
Sep 2, 2004 03:53 PM
