Help with P1354 code
Old Apr 3, 2026 | 11:25 AM
luminous's Avatar
luminous
1st Gear
Default Help with P1354 code
Hi guys. I just replaced both valve cover gaskets on my car. When reassembled, it ran great with no engine light until it warmed up. After about 5 minutes of idling, engine and VSC light came on with P1354 code.
The connector for it was in rough shape, so i bought a new one and replaced it, same issue. I also replaced the camshaft position sensor on bank 2 because that connector was rough, still no luck.
I tested the solenoid with it out of the car hooked up to 12v and it clicked like it should. I ordered replacements for both solenoids just in case.
The car runs great, no hesitation or anything even after warmed up, it just idles high (1300-1400rpm rather than 600-800rpm) when the engine light comes on.
Is there anything I am missing or anything I can do while I wait for the parts? I will avoid driving it until fixed. This is the only code. I change my oil religously. I cleaned the solenoid with brake clean and still no dice.
Any advice is much appreciated. Thank you
lex1181
Dec 11, 2025 11:01 AM
lykacper
Jun 8, 2025 07:03 PM
Lexusguy18
Jun 7, 2023 07:39 PM
karan1193
Jan 7, 2015 08:33 PM
Pirates81
RX - 1st Gen (1999-2003)
Sep 14, 2006 03:55 PM
