things to look out for?
Old Mar 14, 2026 | 11:05 PM
odomlim's Avatar
odomlim
3rd Gear
Default things to look out for?
im thinking of getting 4th gen ls460 is there anything i should look out for or should i go for an ls430 for my first car.
Old Mar 14, 2026 | 11:15 PM
Leadfoot6's Avatar
Leadfoot6
I would not get either as a first car.
Get something much less complicated to learn on first.
Old Mar 14, 2026 | 11:17 PM
odomlim's Avatar
odomlim
3rd Gear
what lexus would you recommend? i already have a car but im saving up for one right now until my brother gets a job so i could give him my old one.
Old Mar 14, 2026 | 11:22 PM
Leadfoot6's Avatar
Leadfoot6
Which country are you from?
How advanced are your mechanical skills?
What tools/workshop equipment do you have access to?
Do you have experience reading diagnostic equipment like Techstream?
It should also be noted that Lexus parts generally have a price premium attached to them.
Old Mar 14, 2026 | 11:28 PM
odomlim's Avatar
odomlim
3rd Gear
im from the us and my mechanical skills are good i used to work at a dealership to do basic maintenance on toyotas and the reason i wanted the ls460 was because of all the features it has and i have access to whatever equipment i need
Old Mar 14, 2026 | 11:31 PM
Leadfoot6's Avatar
Leadfoot6
Armed with such experience you should be reasonably capable of making your own decisions.
Furthermore, there are plenty of material available to you in both 430 and 460 sub-forums to find out whatever you need as to what problems they present.
But again, I would stay away from both if you are on a tighter budget, which I expect that you might be.
Being versed in Toyotas as you say you are, maybe Corollas or Camrys might be more suitable for now.
Old Mar 15, 2026 | 06:11 AM
chrispap's Avatar
chrispap
You are good to go in terms of mechanical skills and access to knowledge and equipment, much, much better than the average first owner.
A few other things to consider: The LS is a big car, sometimes new drivers do better with smaller cars that tend to be easier to drive. Depending on what year LS you buy, you may be missing newer safety and infotainment features. A car like the LS will use more gas, and more importantly it needs premium gas. Finally, assuming you are young, the LS may not impress your peers as much. I ended up with my LS because the 40-year old son thought it was too much of a grandpa car.
If you are OK with all that, then go for it.
Old Mar 15, 2026 | 10:43 AM
Lares733's Avatar
Lares733
Same here. You will not be happy. Gas mileage with premium fuel is brutal. Labor intensive repairs, even as DIY. Plenty of used parts, not so much aftermarket. In the + side, very plush, comfortable vehicle. Also, very reliable if it's been looked after.
Consider other Lexus models.
Good luck.
Old Mar 15, 2026 | 01:50 PM
sktn77a's Avatar
sktn77a
You can get most of the features of the LS460 in an ES350. For the same price, it will be 5-6 years newer, get much better gas mileage, and generally be more reliable (and MUCH cheaper to fix if/when something goes wrong).
FlexnLexus
Nov 13, 2022 01:32 PM
KING
Dec 19, 2014 08:32 PM
handoverfi
Lighting
21
Jun 23, 2009 04:22 PM
VQT
Feb 27, 2008 09:03 AM
mighty~mar
Jul 27, 2006 09:17 AM
