Help: Problem w/ Low-Beam HID Headlights - Won't Turn On!
Hi, I have a SC400 w/ aftermarket HID's installed. Last night, I parked the car at a restaurant with the headlight switch set to the automatic mode. I turned the car off and went inside to eat dinner. Afterwards, I turned the car on and the headlights turned on for about half a second to a second... afterwards, they died and would not come back on. All my other lights still worked fine including my high-beams. The low-beams will not turn back on. I checked the fuses behind the battery and they were all fine. I can hear the "HEAD" relay click everytime I take out one of the "HEAD" fuses... not sure how to check if the relay still works or if that's the right relay for the low-beams.
Anyone have any advice for me on what this problem could be? Thanks.
yeah,need some info...new/used,35/55 Watt....if they both turned off it sounds like a short somewhere...I would say the fuse first but,you said it was fine...could be the factory relay..it's not your bulbs cause they wouldn't both burn out at the same time....
edndiana
12-15-17 12:02 PM
