Is my belt tensioner bad or just the pulley? How can I tell?
Hi,
On the coldest day this year, I started the car and It sounded like metallic birds chirping under the hood. As I accelerated, I could hear the intensity and pitch go up and back down when I slowed. The same day, when I turned on my heat and radio (lights were on), the idle dropped and the car nearly stalled. It happened anytime I was at a full stop, in gear with heavy electronic accessories on. If I rev it a bit in neutral, it stays on.
1) I was told it was my tensioner making the noise. If the tensioner is bad, could it cause the belt to slip (not properly turning the alternator) causing my voltage to drop too low, or is the alternator likely going as well?
2) (in simple nubs terms) How can I tell if I need just the pulley, or the whole tensioner assembly?
3) Are there any non Lexus replacements that fit perfectly (without mods) and last long.
I was told I needed part number 16620-0W030 after I gave him my VIN.
PS: possibly useless data point. I ran the car through the wash yesterday and when I got out, the noise was gone and it didn't try to stall for 45 minutes or so.
(strange)
Thank You!!
SG
(strange)
Thank You!!
SG
I always start with the belt. if the belt has worn enough the tensioner will be at a point where it tends to rattle alot as it moves sideways. you can usually tell with a flashlight if its kicking alot side to side. there are also tick marks on the side of the tensioner and a little pointer thing, and if its inbetween the lines or on a line its still alright, if its way outside those marks then indicates a worn belt or tensioner.
usually its the pulley bearing though that makes the noise from all this extra movement of a worn belt and gets damaged and the bearing makes a noise from just spinning, changing the belt will not solve the noise at this point. you can shoot the front of pulley with some wd40 and see if it changes the pitch (dont shoot the belt or top of the pulley). if so you can get the bearing pressed out and install a new one, or maybe they sell the whole pulley not sure.
If you take the belt off and give it a spin it should be obvious its the pulley or not.
Much appreciated man!
SG
StudioGeek,
I just purchased the exact same car this week (my toy) and the screeching sound is here as well. About to go to Lexus to purchase the tensioner. Paperwork that came with the car shows they've attempted to address the noise by installing a new belt so either pulley or tensioner and I figure I may as well replace both while in there.
StudioGeek,
Pulleys from AutoZone and Advanced...major FAIL. The learning is good...even better when you accomplish what you set out to do. Where I am now is ordering Lexus tensioner with pulley built in for almost $300 but after the time spent today I would have gladly paid that to now be finished with this project. Sage advice on the belt. The previous owner recently added new belt but I almost want to start from scratch to be able to put together my own sked/calendar
Gates makes 2 tensioners, the one that fits and the one that doesn't (requires modification to sort of fit). The one that fits is the #39080 which sells at Amazon for $118. It is an exact fit and just slides in without any modification and without hitting the timing covers. I just installed one. The other one is about half the price. The choice is yours. I chose the one that fits.
Gerry
Gerry
Gerry
Gerry
Thank you!
SG
Awesome info...great share
Gerry
Gerry
On another note, I've barely had this car for two weeks and in this forum I have already been blown away by the sharing of info. This is an awesome spot and I greatly appreciate you all...
Hala
So with the belt on Ali where should the pointer mark be in between
or first tick to left there is three on left and space the one on right
