Power steering flush
Old 09-02-09, 09:19 AM
boris
boris's Avatar
Default Power steering flush
Just wandering which brand to use to do this. Since they no longer have dexron II, will the current IV or higher one be compatible? Do you guys use synthetic or no, my car has 132k? Comments, thanks guys.
Old 09-02-09, 09:30 AM
BLKonBLK98
BLKonBLK98's Avatar
mobil 1 synthetic atf for me.
Old 09-02-09, 11:09 AM
Black94GS
Black94GS's Avatar
i used the lucas one and it stopped my rack/pinion leak
Old 09-02-09, 01:25 PM
damon
damon's Avatar
I use Royal Purple Syn PS Fluid.
Old 09-02-09, 04:16 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
use a DexronIII spec fluid for the PS.
Old 09-02-09, 08:40 PM
boris
boris's Avatar
So, PureDrifter, do you recommend synthetic or non synthetic? Thanks
Old 09-02-09, 09:43 PM
nthach
nthach's Avatar
I'm using Valvoline MaxLife ATF in my power steering. Royal Purple and Lucas is overrated - and Lucas can exacerbate pre-existing issues since it's so thick and doesn't have enough defoamers in it.
I did run Red Line D4 ATF in it before - I felt the steering was a touch lighter with RL.
Old 09-03-09, 12:55 AM
damon
damon's Avatar
Have never seen anyone rate RP or any PS Fluid for that matter.
The better question for this thread is how often should you be changing this fluid to prevent ever having to replace your PS Pump?
Once was enough for me so I am now fairly diligent.
LsG86
03-08-15 02:52 PM
dbui
RX - 1st Gen (1999-2003)
07-03-13 04:30 AM
hlu1
IS - 1st Gen (2001-2005)
02-22-13 11:53 PM
Ariyanna
11-30-09 06:02 AM
JCtx
Maintenance
08-15-06 07:31 PM
Quick Reply: Power steering flush
