timing belt skip a tooth?
Old 12-10-08, 08:40 PM
Dereke
Dereke's Avatar
Default timing belt skip a tooth?
cruisin down the street in my six-fo... er LS i mean..
car suddenly sounded very loud through the intake side and a very noticable loss of powers. wont revv past 5k now and im thinking its maybe timing? how do i check timing? i dont see any way to adjust it. are there any other ideas you guys have?
thanks
Old 12-10-08, 08:49 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
sounds like spark or fuel died.
what year LS?
Old 12-10-08, 08:51 PM
Dereke
Dereke's Avatar
sorry for the dots. 93 is too short of a post. gay ****
Old 12-10-08, 08:59 PM
LiCelsior
Retired
LiCelsior's Avatar
def sounds like spark died...infamous ign coil maybe.
Old 12-11-08, 12:18 PM
Dereke
Dereke's Avatar
k ill check the coils.
Old 12-11-08, 01:22 PM
Dereke
Dereke's Avatar
dumb question but where is the crank speed sensor and what does it do? i know about the cam angle sensors
Old 12-11-08, 09:09 PM
trukn1
NELOC Mod
trukn1's Avatar
www.lexls.com. Don't make it harder on yourself than necessary. Your problem sounds, as LICELSIOR said, like the ignition coil/coils have gone bad.
Old 12-11-08, 09:20 PM
LiCelsior
Retired
LiCelsior's Avatar
lol his problem lead me thinking about ur thread on ur ign coils T.
Old 12-11-08, 09:48 PM
Dereke
Dereke's Avatar
checked the coils. both have very healthy spark. it runs fine at part throttle and even sounds like it should under id say 2500 rpm. pulled engine codes and nothing came up. lexls shows marks on the timing belt and cam pulleys but i dont see any on my belt or pulleys. i pulled the egi fuse and turned the motor over looking for the marks on the belt. ran out of daylight but didnt see any. timing is the only thing that fits for me. i replaced the fuel filter and did seafoam treatment maybe 7k miles ago. replaced all plugs and wires and put in new cam sensors and a junkyard afm that seemed to be ok, all was done less than 4k miles ago and it was running like a champ till this.
thanks for any additional help you guys can give.
Old 12-12-08, 05:54 AM
19psi
19psi's Avatar
if it's running, it's not spark or fuel. look for vacuum leaks. maybe even your intake tube after the maf has a leak somewhere.
HalifaxSC4
Performance & Maintenance
08-11-16 12:15 PM
Cashflo
23
07-19-11 11:03 PM
ewenpg
06-11-10 04:14 PM
PlatSilvSc
01-29-07 07:30 PM
bmorones
09-29-04 08:00 PM
Quick Reply: timing belt skip a tooth?
