Dome light connect
Dome light connect
LS Electrical gurus I need help! Looking for a domelight wire tap location anywhere near the front dash. Tried at the dome light no go (constant 12V+ there also at the footwell lamps. Need it to be energized when domelight is on.and off when domelight is off.
Yes, the wire at the domelight is constant hot. So I'm not an electrician but I can follow instructions pretty well. What I have is a suspension (wheel) light kit installed and it has a orange +12v input that you can wire in an alarm trigger or something like that.
What I want to do is wire into my domelights so they come on and go off as the domelights do.
Can you offer easy to follow instruction as to what wire needs to be attached where?
Thks
Thks
