lighter socket problem
Old 04-30-04, 10:21 AM
ryanwtyler
ryanwtyler's Avatar
Default lighter socket problem
i'm trying to use a lighter accessory and i am receiving no power. Do you know of a way to fix or diagnose the problem without going to Lexus?
Old 04-30-04, 10:29 AM
ultra63
ultra63's Avatar
I had this problem on a 98 LS400. The solution was to use the accessory one under the arm rest. not the cigarette lighter. I had the dealer check the cigarette lighter and they said it was OK. Apparently it lights cigarettes but is an unrelaiable power source.
Old 05-01-04, 10:30 AM
SharpLS-96
SharpLS-96's Avatar
He has a 92 LS, I don't think he has a 12-volt power adapter plug in his center arm rest console.
Does your actual cigarette lighter work when you push it in or no?
If not, check your fuses in your fuse box panel.
Old 05-02-04, 11:23 AM
ryanwtyler
ryanwtyler's Avatar
the lighter does not heat when i push it in. where is the fuse box?
Old 12-22-07, 08:12 PM
VipBoss
VipBoss's Avatar
I. am curious also. Having the same problem where is the fuse box located?
Old 12-22-07, 08:44 PM
LiCelsior
Retired
LiCelsior's Avatar
there is one under the hood and one under the steering wheel. behind the diag port there is the fuse box.
Old 12-22-07, 09:49 PM
trukn1
NELOC Mod
trukn1's Avatar
Cig lighter problem is a common one. Very easily burned out and the socket had to be replaced.
Old 01-03-08, 10:25 PM
BIGBADDAD
BIGBADDAD's Avatar
I am having the same problem with my 94 ls400, I keep blowing the fuse. There must be a short to ground, but I have no ideal where to start. Does anyone have any sugestions? My lighter looks new, I have never used it, the car has never been smoked in????? HELP.
Thak you.
Mark
Old 01-04-08, 10:25 PM
Zero_One
Zero_One's Avatar
If it is not a fuse and you have power going to the connector on back of the socket, there is a small "solder" connection on the bottom of the socket so if the lighter sticks and keeps getting hotter the solder connection will melt as to not burn down the car. If you are good with a a soldering iron then you can just fix it! It is a pretty easy fix....
Old 01-05-08, 07:56 AM
Dutch
Dutch's Avatar
i had this problem in my 92 and i checked my fuses which turned out good then i pulled the socket out to check the wire connections which also looked good. after that i decided to plug something in hoping that it would work(thinking maybe i moved something back into place) and apparently i did b/c it still works to this day.
Old 01-05-08, 05:54 PM
Smoothie22
Smoothie22's Avatar
I have the same problem. Can I just replace the whole set-up?
Old 01-15-08, 11:58 AM
slimlma04
slimlma04's Avatar
i have the same prob, except my front lighter dosent do anything at all... i think i need to change th socket it self...
Pinio
09-29-18 02:13 PM
randy2016
01-10-13 02:03 PM
Deegee
08-25-12 07:05 AM
JustInGS3
08-04-09 12:03 PM
chliansh
04-11-03 12:22 AM
Quick Reply: lighter socket problem
